Old 06-09-2013, 03:18 PM   #1
Glen e
Glen e's Avatar
Drives: Garnet 2LT RS
Meg's strong to weak abrasive chart
Glen e is offline   Reply With Quote
Old 06-09-2013, 03:39 PM   #2
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
Also, 101 is in front of 105 and 100 is slightly below 105.
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517
"When you want to succeed as bad as you want to breathe, then you will be successful."
Old 06-09-2013, 07:44 PM   #3
chicagobulls
one car wolfpack
chicagobulls's Avatar
Drives: 2010 Camaro V6
Nice post this is good to know.
chicagobulls is offline   Reply With Quote
Old 06-09-2013, 09:18 PM   #4
Good_Times
Drives: red
From my use of M105 both the old and new versions and M100 I give the nod to M100 for cut and working time. IMO. Need to add a few to the line-up like 66 and D300. Meguiars does have a lot of good solid compounds.
Good_Times is offline   Reply With Quote
Old 06-10-2013, 12:08 AM   #5
ihaveacamaro
I like teeth.
Drives: #198
I haven't done any direct testing, but what I was saying is what I was told in a class by Jason Rose at Autogeek's Detail Fest.
Old 06-10-2013, 12:10 AM   #6
AmericanMuscleCars
Teenage Dream Camaro
AmericanMuscleCars's Avatar
Drives: A Visually Stunning Camaro
Wait, so the scratch 2.0 isn't a type of thing that you just put on a Microfiber and work it into the scratch?
AmericanMuscleCars is offline   Reply With Quote
Old 06-10-2013, 12:12 AM   #7
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Name dropper.
[B]
Old 06-11-2013, 08:40 AM   #8
Good_Times
Drives: red
Is that like staying at a Holiday Inn Express / j/k. I have seen Jasons comments on MOL but I think it depends on paint hardness and pad selection. Even with that it's very close. Where M100 shines is it's longer working time which might make it appear to be cutting faster. M105 is slowly dissapearing from my inventory. M100 and M101 have replaced it along with a few HD and Sonax products. Keep a eye out for 3D/HD to release HD ADAPT soon.Got lucky and have been testing it for Tunch Goren at 3D along with a dozen other guys. Check the facebook group for more info.
Old 06-11-2013, 08:48 AM   #9
Good_Times
Drives: red
Scratch-X is excellent for working by hand.On a mf applicator or mf towel when doing a small scratch is where it shines. If you were to use it with a da and mf pad you would find it fairly aggresive. I have given it to plenty of Harley riders to carry in the saddle bags for removal of small scratches. Quick and easy. They mostly love it.
Old 06-11-2013, 12:06 PM   #10
nUcLeArEnVoY
Oldbie that nobody knows
nUcLeArEnVoY's Avatar
Drives: 2011 1SS/RS M6
M101 foam-cut compound is supposedly stronger than M105. It's a rather recent release, so I haven't tried it yet.
nUcLeArEnVoY is offline   Reply With Quote
Old 06-11-2013, 12:11 PM   #11
LIM3
it's mind bottling..
LIM3's Avatar
Drives: SGM
101 is stronger than 105 I believe
Old 06-11-2013, 01:14 PM   #12
Good_Times
Drives: red
M101 is extremely high cut. Remember to always start with the least abrasive product on a test spot. Never use stronger then you need to do corrections. There is only so much clearcoat and once its gone, its gone. You can adjust cut with a mixture of compounds. Kind of a custom blend . Many use M101 and D300 or M105. Some compounds are known for their cut while others their working time or finishing ability. Just a thought.
