Old 06-09-2013, 05:24 PM   #1
etmx183
etmx183's Avatar
Drives: 2012 Camaro 2LT RS
Dyno Numbers today
I was hoping to be closer to 300 but I see it running a bit rich and it was hot out.
etmx183 is offline   Reply With Quote
Old 06-09-2013, 05:26 PM   #2
etmx183
etmx183's Avatar
Sorry The photo will not attach but it is in my "Toys" album
Old 06-09-2013, 05:27 PM   #3
etmx183
etmx183's Avatar
Old 06-09-2013, 05:30 PM   #4
etmx183
etmx183's Avatar
Max power = 271.76 Max torque = 241.15 AF was almost dead on 12.0 from about 6300 - 6800 RPMs
Old 06-09-2013, 07:05 PM   #5
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2012 2LT RS
Would have thought it would be higher. I was 269/236 before doing trifecta, solo, and Tru xpipe. Was 92 at 58% humidity. I will be pissed if I don't get closer to 285 now.
2012: e85, 80mm TBody, CAI w/scoop, Solo HFC, ZL1 FP, Magnaflow TruX, Dynomax VT, Elite catch can, HP Tune, Throttle Contoller, BMR; Springs, Sways, Trailing Arms, Toe Ends, & Safety Loop, Koni str.t, Pioneer Z150bh, Phoenix Gold Sub, Hertz speakers & 5ch Amp, 1LE rear with 3.91 gears, BMR bushings, Baer Decela Rotors, Goodridge brake lines, Brembo(GM) 4 piston calipers, Hawk Ceramic pads, ported intake, Circle D 5c. 12.3@112 old setup
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
IneedAZ is offline   Reply With Quote
Old 06-09-2013, 07:51 PM   #6
KMPrenger
KMPrenger's Avatar
etmx,
Yeah it seems bit low, would have expected closer to 280, but really its not all that bad.
To get close to 300rwhp on an automatic you need to be pushing 370 - 380 crank HP which just isn't going to happen very easily with bolt ons and a tune. A manual will have a much easier chance of reaching close to the 300rwhp mark.
Assuming your dyno numbers are spot on (which they practically never are) means your at roughly 340HP and a hair over 300TQ at the crank. Again I'd expect you to be more in the 350 range but not too shabby.
KMPrenger is online now   Reply With Quote
