Gen5DIY
Old 06-10-2013, 12:47 AM   #1
Juice2SS
Drives: 2011 2SS
PO171 code after burning bank 2 o2 sensor wire.
So I replaced the wire and reset the PCM. I had a PO174 before the repair of the wire. Think I might have hurt the sensor?
Juice2SS is offline   Reply With Quote
Old 06-10-2013, 10:27 AM   #2
Juice2SS
Drives: 2011 2SS
I should mention that this was the O2 extension wire that was burned. Not the wire on the actual sensor itself.
Old 06-10-2013, 10:31 AM   #3
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
It could have killed the sensor, I have seen it happen before.
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
shop.gwatneyperformance.com ryan@gogwatney.com josh@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
Old 06-10-2013, 10:33 AM   #4
Juice2SS
Drives: 2011 2SS
Piss... those things are $100. lol
Old 06-10-2013, 10:17 PM   #5
Rhino79
Rhino79's Avatar
You could change them from side to side and see if the code follows the sensor before replacing it.
Old 06-10-2013, 10:47 PM   #6
Juice2SS
Drives: 2011 2SS
True... hmmm. I'll do that tomorrow.
Old 06-11-2013, 02:00 PM   #7
Juice2SS
Drives: 2011 2SS
How the hell is the L99 O2 sensor more expensive than the LS3? They have two different part numbers. :-/
Old 06-11-2013, 02:25 PM   #8
union894
union894's Avatar
Drives: 2016 Camaro 2ss 8A 13 Cadillac SRX
I came on to check the same situation on my LS3, installed LTH the other day, check light came on, popped the hood drivers side O2 extension is laying against the header, I thought I had it tied back, wrong
union894 is offline   Reply With Quote
Old 06-11-2013, 02:32 PM   #9
Juice2SS
Drives: 2011 2SS
Well verify your sensor is ok. My car has been running like poo in the midrange and getting weird mileage since it melted.
Old 06-11-2013, 02:43 PM   #10
union894
union894's Avatar
mines running good just has the light on
Old 06-11-2013, 02:45 PM   #11
union894
union894's Avatar
I'm sure my extension is shot
Old 06-11-2013, 02:56 PM   #12
Juice2SS
Drives: 2011 2SS
Mine was fine for a while also. lol
Old 06-11-2013, 07:32 PM   #13
Rhino79
Rhino79's Avatar
You get it figured out Juice???
Old 06-11-2013, 09:30 PM   #14
Juice2SS
Drives: 2011 2SS
Yup! Replaced the sensor and its running STRONG again. I think my AFR is off during cruising. My MPG was down immediately after the tune during the 48 hours afterwards. How can that be adjusted?
