Old 06-10-2013, 04:12 AM   #1
Erad
Drives: Camaro SS 2010
Post Engine misfire
Hey guys, I'm actually new to LS3 engine. I have recently purchased a Camaro SS 2010 and it has some work done on the engine. Unfortunately I don't know what exactly but as per my experience the below modifications:
1. Cam
2. Intake
3. Throttle body
4. High pressure piston
5. Air intake
6. Headers and one chamber cat back
I have tuned the car recently and since I'm in Dubai the temp in the summer is really hot so additionally I have kept and engine oil cooler as well. I'm using MSD wires and my tuner advices that I should go with NGK 7. However, after my research I noticed everyone is recommending to stay with the AC Delco stock plugs.
The issue what I have the car from rpm 1 to 2.5 has a misfire and after that everything goes normal and the other issue I have the all the lights on the dashboard are on! such as traction control, abs, airbag and sometimes the check engine sign. The car had no accident. However, my tuner says its because of the modification done to the car you can not get rid of these lights and since you have misfire.
Sorry for the long story, but I would appreciate if anyone can help me out here. Thanks
Erad is offline   Reply With Quote
Old 06-10-2013, 05:39 AM   #2
Da Mammer
Drives: 2010 camaro SS LSXFoFiddyFo
Well lets see where to start. I'm guessing its a manual transmission if its an auto then it's a whole new can of poop in your wheaties. Im going to assume the cam you speak of has a stupid long duration, If it has a big cam in it and has a rough lope on idle I'm assuming that's where your misfire is coming from until 2500rpm. Your tuner should be able to lower the sensitivity of the misfire detection of he doesn't know that find yourself a different tuner. it is probably the source of your engine light being on. Secondly your 3 lights associated with abs traction control are going to light up BECAUSE of the cylinder misfire trouble code. So you have to fix the misfire code and the traction control/abs lights should go off less something else is wrong. As far as your airbag light I'm lost do you have non-stock seats in the car? Or a simple steering wheel? Somewhere someone may have disconnected an air bag on a seat to pull the seat out to shed weight for racing maybe? May have to take that one to a dealer to clear the code. And finally I'd stick with ac delco. If ac delco is good enough for a ls9 to zz572 it should do the job in your 6.2L
LSXTC
Da Mammer is offline   Reply With Quote
Old 06-10-2013, 06:13 AM   #3
Erad
That's right it's stick shift and its has a big cam because on the idle its rough. I will take it to a different tuner and I hope it works out. The seats are original and has not been changed. However, all the lights which I mentioned it comes and goes! I will stick to the stock spark. Thanks a lot
Old 06-10-2013, 08:15 AM   #4
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
I seriously doubt some one put a high pressure.....pistons on the car its probably the same normal pistons as we allready have to use high octane...sauper gas and run premium.......you see dissassembling the entire motor to change only the pistons and cam is not very money friendly......ANd yes the lope of the more radical cam may be what is saying misfire as your timing is off from firing just right or the computer can not handle it................or you have a bad spark plug that has a small crack and misfires when it wants. Changing intake is ok yet expensive with not much gain...like 1000$ expensive and 3 h.p. ........... SO who ever built the car may not well have known what money to throw where at the car to try to make it perform better..................
2013 2SS/RS LS3 M6 ,CRT, NPP, Forged 428 ls3 stroker, GMPP ported heads, Katech chain, Mast windage, Cam Motion Cam, trunnion upgrade, Stainless Power headers HFC, CAI w/kit, Vmax PTD, Fluidampr25% udp, LPW diff cover, BMR strut brace,trailing arms, toes, bushings, Rocket racing wheels,Toyo Proxes 4+, elite catch can, clutch reservoir, dash/body LED, DRL rewire, Sparks billet badges, Forza 3way, tint, MRT louvers, ZL1 spoiler, MGW short throw, Monster dual LT1S clutch, bleeder, support, high vol pump, Speed hut shift light, ACC flames stripes, Driven ls30 oil, NGK TR6IX , Granatelli wires.
Old 06-10-2013, 12:21 PM   #5
Sword5
Sword5's Avatar
Drives: 2010 2SS
Could have a cracked or broken plug when headers were installed.
Ordered 6/19/09 Black on Black 2 SS Delivery 10/14/09! Added CAI, Heritage Grill, DRL Plug and Play Harness
Sword5 is offline   Reply With Quote
Old 06-10-2013, 12:29 PM   #6
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Drives: 2012 CRT NF Cammed 2SS/RS
Im not 100% sure, but I think people have the same mods as you and do not have to live with the check engine, etc lights on.
You may need a new tuner, or get a mail order tune from Jannety Racing, that you guys can send files back and forth through email, and he may be able to fix your issues.
Old 06-10-2013, 10:02 PM   #7
oville-rider
oville-rider's Avatar
Drives: 2010 Camaro Summit White 2SS/RS
1. Cam
2. Intake
3. Throttle body
5. Air intake
Well if I'm reading this right you bought the car with mods 1-6 already installed. Since then you've replaced the plugs and wires? You could have possibly damaged a plug or don't have a wire pushed on fully. Easily done ! If you have a OBD II scanner depending on it's capabilities you might be able to checks things in run mode. It may tell you what cylinder is misfiring? If not go back and check each wire first to see if they are on all the way, then plugs for damage. I would stick with the stock plugs but that's me. Good Luck
oville-rider is offline   Reply With Quote
Old 06-11-2013, 03:13 AM   #8
Erad
Thanks a lot guys. I have dropped the car to a tuner and he will be doing full diagnostic on the car and fingers crossed he said it will be ready in two days with all the problems solved. Once I receive the car, I will share with you guys what the issue was. Thanks again
