Gen5DIY
Old 06-10-2013, 05:18 AM   #1
Erad
Drives: Camaro SS 2010
Unhappy Engine misfire
Engine misfire
Hey guys, I'm actually new to LS3 engine. I have recently purchased a Camaro SS 2010 and it has some work done on the engine. Unfortunately I don't know what exactly but as per my experience the below modifications:
1. Cam
2. Intake
3. Throttle body
4. High pressure piston
5. Air intake
6. Headers and one chamber cat back
I have tuned the car recently and since I'm in Dubai the temp in the summer is really hot so additionally I have kept and engine oil cooler as well. I'm using MSD wires and my tuner advices that I should go with NGK 7. However, after my research I noticed everyone is recommending to stay with the AC Delco stock plugs.
The issue what I have the car from rpm 1 to 2.5 has a misfire and after that everything goes normal and the other issue I have the all the lights on the dashboard are on! such as traction control, abs, airbag and sometimes the check engine sign. The car had no accident. However, my tuner says its because of the modification done to the car you can not get rid of these lights and since you have misfire.
Sorry for the long story, but I would appreciate if anyone can help me out here. Thanks
Erad is offline   Reply With Quote
Old 06-10-2013, 08:59 PM   #2
Taser Deployed
Taser Deployed's Avatar
Drives: 2012 Blk ZL1
You'll probably get more responses if you post in the SS specific forum.
Taser Deployed is offline   Reply With Quote
Old 06-10-2013, 09:07 PM   #3
The Stig
knows 2 facts about ducks
The Stig's Avatar
Moved
Click to view my build thread
Old 06-10-2013, 09:12 PM   #4
flyer08
Drives: 2010 2SS/RS
Good luck. I'm no help but hopefully someone can get you straitened out and possibly better tune. Sounds like that's what you really need
flyer08 is offline   Reply With Quote
Old 06-10-2013, 09:58 PM   #5
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
Check your plugs and wires, then get a tune from someone who knows what they're doing.
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 06-10-2013, 10:21 PM   #6
2012InfernoSS
2012InfernoSS's Avatar
Drives: 93GMC sierra stepside/2012 SS
X2
Id guess one of the plug wires are not on all the way
2012InfernoSS is offline   Reply With Quote
