AAC Style
Old 06-10-2013, 02:54 PM   #1
ADM PERFORMANCE
Drives: 2016 CAMARO SS
ADM PERFORMANCE Wireless Exhaust Valve Control thread
Here is were we would like those who ordered our first batch of exhaust controllers to post about the new Wireless ADM Exhaust Valve controller for ZL1 AND ALL FACTORY EQUIPPED NPP CAMAROS.
Here is the preliminary written instructions,please be advised they will be updated based on feedback and future changes if any.
All work is done in the trunk.
Removal:
Remove rear cargo Carpet.
Remove black rear trim panel .
Fold back passenger side rear carpet to access fuse block and new mounting point for controller
Unplug small 2 pin connector/harness that goes through the floor.
Push harness and grommet through the floor exposing it on the other side.
Unplug 2 pin connector at flapper solenoid (above passenger side muffler behind tire)by squeezing hard on metal wires on each side and pulling abruptly. See pic
Install new harness in reverse order.
Install:
Once you have the new harness installed with grommet properly secured in place and connectors properly plugged in you can now install the ADM CONTROLLER
Install velcro in proper location to mount control box.See pic
Remove fuse block cover.
Plug new white connectors together from ADM CONTROLLER TO HARNESS YOU JUST INSTALLED(Only plugs in1 way)
Install nut plate clip were hole is just below factory ground.
Install supplied bolt through relay and bolt to nut plate.(Use 10mm socket)
Remove factory ground bolt and install ground bolt through eyelet in wiring harness.Tighten to 90 inch pounds with 10mm socket
You are required to solder and heat shrink of tap into the pink wire on the back side of the fuse block for power.The red wire is power from the adm controller.
NOTE - THE BLUE WIRE IS THE ANTENNA,A SUPPLIED TYE WRAP CAN TIE IT UP IF NECESSARY
ADM PERFORMANCE is offline   Reply With Quote
Old 06-11-2013, 10:52 AM   #2
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '15 Z/28
Thanks Andy!
'15 Z/28 #325 black a/c & stereo. 2:10.5 VIR Full 1:44.74 Summit Point Shenandoah Circuit
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 06-11-2013, 11:41 AM   #3
zfuzz
zfuzz's Avatar
Drives: 69 Z28 / 12 ZL1
How does the controller work, a wireless key chain controller, through the homelink buttons ? How does it differ from the "Mild to Wild" switch?
zfuzz is offline   Reply With Quote
Old 06-11-2013, 11:45 AM   #4
Garys16SS
Garys16SS's Avatar
Drives: 2016 SS, BLACK, MANUAL
Andy, do you have an ETA yet for delivery???? The neighbors are getting restless!!
2016 Black/Black SS, 6speed, MRC, Roto-Fab air intake, Vitesse controller,
1 7/8" headers and exhaust from Stainless Works complete with nonNPP mufflers and 5"outlets, Katech ported TB, Moroso catch can, MRR M017 polished powder wheels, Eibach lowering springs, and BMR upper/ lower trailing arms and upper control arms. ZL1/1le sway bars and Magnusson Supercharger with Jannetty tune. Stay Tuned!!!......More to come.
Garys16SS is offline   Reply With Quote
Old 06-11-2013, 01:22 PM   #5
Stephen12ZL1
Drives: '15 Z/28
UPS tracking says mine should be here on Friday!!
Old 06-11-2013, 01:58 PM   #6
Stephen12ZL1
Drives: '15 Z/28
"closed" or "stock" operation for this ADM unit which is unlike anything on the market. Mild to wild can only go to "open" or "stock"
Old 06-11-2013, 06:42 PM   #7
ADM PERFORMANCE
Exactly.... If he had headers he would understand
Old 06-11-2013, 07:11 PM   #8
babigguy
babigguy's Avatar
Drives: 2009 trailblazer ss and 2013 ZL1
Any chance of this being closed,stock,and open?? And can you pm me a price?
Jannetty Racing 75hp no tune kit, xpel, showstoppers lights-sidemarkers-flaps, nitto 555r's, torco race fuel
babigguy is offline   Reply With Quote
Old 06-11-2013, 07:20 PM   #9
DrkPhx
DrkPhx's Avatar
No kidding. I swear it's louder with headers on start up compared my old 98 TA which had a stroker motor with a big cam and high compression.
I should have mine tomorrow so I will make sure to report back. This kit should sell pretty well as more owners with dual mode exhaust modify their cars. IMO this is the hot exhaust set up for these cars. Best of both worlds.
Old 06-12-2013, 07:38 AM   #10
ADM PERFORMANCE
Unfortunately no.
It's open all the time at idle anyway from the factory.
I'm still not sure why you would want it open all the time anyway?
Please explain?
Old 06-12-2013, 07:56 AM   #11
Stephen12ZL1
Drives: '15 Z/28
Unfortunately no.
Please explain?
I think some people like their ear drums to bleed! Or "there can never be too much sound!!"
Old 06-12-2013, 08:52 AM   #12
G4M3OVR
G4M3OVR's Avatar
Drives: '05 OB Neon SRT4, '13 IOM ZL1
^ This.
G4M3OVR is offline   Reply With Quote
Old 06-12-2013, 01:38 PM   #13
hognutz
hognutz's Avatar
Drives: 2013 ZL1
Hey Andy did you sell all of the first ten kits?
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 06-12-2013, 01:55 PM   #14
Garys16SS
Garys16SS's Avatar
Mine too!! Thanks Andy!!
