Caryle Racing
Old 06-11-2013, 10:43 AM   #1
suros123
Drives: Camaro 2010 SS
Problem with rpm
I own a camaro ss 2010, imported from California to Slovenia (Europe). I hope someone can help me. The problem is when the car run in neutral, the rpm's vibrates for about 50-100 for around 30s. Then it stops. I visit already 2 services. First is authorised for Cadilac,Corvete,Humer and the second delas with US cars. Both told me that that`s normal, but i think it`s not.
So does someone have some similar experience and can someone help me with my problem ?
suros123 is offline   Reply With Quote
Old 06-11-2013, 10:51 AM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
When you say "it stops," do you mean the car stops or the RPM variation stops?
Click to view my build thread
Old 06-11-2013, 11:00 AM   #3
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
Are you saying that it is fluctuating 50-100 rpm (550 RPM +/- 100RPM) after a clutch depress? If so, I am pretty sure that is normal. Mine goes +/- 200 RPM or more after the cam install (idle at 850 RPM). It is the idle control PID settings that are not quite perfect.
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
Old 06-11-2013, 11:44 AM   #4
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
That's a MERICAN! Racecar! Normal! Now go get long tube headers and take mufflers off! Do it, do it noooow! Represent us good over there please.
Thank you.
Old 06-11-2013, 12:52 PM   #5
suros123
Bell040.... yes the RPM`s are fluctuatin.
Do you know maybe how to set the idle control PID so that there won`t be any fluctuation ?
Old 06-11-2013, 01:53 PM   #6
Bell040
Bell040's Avatar
You have to program the PCM which requires a tune or a factory recalibration. Most tuners do not mess with the PIDs, so you would need to take it to someone good. If it is under warranty... you might find a master tech that would give it a try if you complain about the idle.
Best bet would to be to get used to it. GM was pretty aggressive with the LS3 cam specs compared to older models... so you might not be able to easily tune it out with going to a milder cam.
Hopefully a tuner will chime in... because this is at the edge of my comfort zone.
Ordered: 10-13-08
Recieved: 6-12-09
Old 06-11-2013, 02:23 PM   #7
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
Probably normal but just curious if you've added a Cold Air Intake recently?
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 06-11-2013, 02:41 PM   #8
suros123
BubbaSS No i dont added a Cold Air Intake. I have all original parts in my Camaro.
Bell040 I have L99 version.
Old 06-11-2013, 04:44 PM   #9
Bell040
Bell040's Avatar
Then disregard my statements.... sorry
Ordered: 10-13-08
Recieved: 6-12-09
