Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Chevy Camaro vs...
Old 06-12-2013, 10:45 AM   #29
FaytalsCamaro
Distributor of Liquor
FaytalsCamaro's Avatar
Drives: My Wife Crazy
dont know what year your v6 is but if it has the LFX engine you cant get headers.
And considering the number 1 person on the v6 fast list for bolt ons comes in at 13.4 with DRs/Skinnies, Injen CAI, ARH Longtubes/High Flow Cats, SS Axle Back, Trifecta Tune. Outside of Force induction I'm going to have to hand it to the nissan
FaytalsCamaro is offline   Reply With Quote
Old 06-12-2013, 10:46 AM   #30
FaytalsCamaro
I apologize i misread your post, with cams I think you would stand a good chance
Old 06-12-2013, 12:25 PM   #31
camaro-dreamer
camaro-dreamer's Avatar
Drives: 2013 Porsche 981S
Originally Posted by omgitsmikeyC View Post
The Camaro 6 has some serious potential for tuning, while the 370Z is almost completely tapped out tune wise for an engine. The Z motor is nearing the end of it's era, as they have to now turbo charge to get over that 420-430 HP bump after seriously modifying the engine. I know a lot of people who have tried, and blew the block because too much pressure and heat. The BMW motor has the same issue on the straight 6, only so much can be brought out before it becomes a time-bomb. Right about the same horsepower range as the Z also. Hell, they both have trouble running without being tuned :P
The 370z has a lot of heat issues. Large aftermarket oil coolers are a must. In addition, there are certainly 370z's with more horsepower than any v6 camaro on this forum. However, the big problem is the torque. Even with twin turbos, I haven't seen any information on a z with more than 500 ft*lbs of torque. In addition, as you mentioned, tuning is a big problem. There are many more camaros than 370z's out there. There is less of an incentive to getting everything exactly right. Apparently, tuners can't get the VVEL tuning down,thus leaving power and durability on the table.
However, that being said, the z has a huge weight advantage. Basically, the camaro needs to be very highly modified (FI) to keep up with a bolt-on z without FI.
camaro-dreamer is offline   Reply With Quote
Old 06-12-2013, 01:59 PM   #32
bowtieguyvegas
bowtieguyvegas's Avatar
Drives: 2012 RS/SS and 2012 2LT/RS
Originally Posted by 08-G35s/6MT View Post
Well I did 13.6 in what basically amounts to the 4 door version of the 370z that weighs 400 lbs more and has a good 30 less hp and 2 less gears. bench racing ftw
Well you must have a speical car cuz here they are mid 14 sec. at best stock. The 350z and 370z are not that fast here, must be the heat and bad Vegas air.
bowtieguyvegas is offline   Reply With Quote
Old 06-12-2013, 02:33 PM   #33
IBM camaro
Texas HT5
Drives: IBM
There is a v6 twin turbo on this forum that made just over 600rwtq running 11s. Look at the FI dyno list and read his build Gretchen
IBM camaro is offline   Reply With Quote
Old 06-12-2013, 05:20 PM   #34
bowtieguyvegas
Originally Posted by RedWingsZL1 View Post
As everyone should know by now. G35 will always be here to inform us that imports smoke camaro's.
His G35 is faster than my ZL1. It's depressing.
Old 06-13-2013, 02:01 AM   #35
08-G35s/6MT
08-G35s/6MT's Avatar
Drives: racecars
No bought I would bet my heads/cam $5k Camaro would give his $50k car a run for its money
08-G35s/6MT is offline   Reply With Quote
Old 06-13-2013, 02:37 AM   #36
dangnplus
dangnplus's Avatar
Drives: 1LT camaro RS package
How is his G35 faster than ur zl1 ....
dangnplus is offline   Reply With Quote
Old 06-13-2013, 02:58 AM   #37
PeeBee
PeeBee's Avatar
Drives: "Bee" ZL585, Dark Blue Suburban.
...irony...
PeeBee is offline   Reply With Quote
Old 06-13-2013, 03:02 AM   #38
OmniCamaro
US Veteran
OmniCamaro's Avatar
Drives: 2011 Silver Ice Metallic 2SS/RS A6
I think he's calling him cretinous; between the lines of course.
Dear Lord, give me the strength to carry on despite my Camaro addiction!
JRE iTSX tune, full cat-less Dynatech exhaust, CAI intake, Stillen Slotted/Drilled Rotors, RB braided brake lines, BMR lowering springs, (reserved for definite future MODS)
OmniCamaro is offline   Reply With Quote
Old 06-14-2013, 12:30 AM   #39
Z/Camaro
Drives: 2012 Vette GS 280z/300zx
The reason you don't see the correct times in Vegas is because LV Motor speedway sucks. I too live in Vegas but I'm originally from California. Compared to the tracks in California the Vegas track is horrible. The prep on the track is the worst. Not to mention, Vegas is at a higher elevation than places that most magazines test cars. So yeah, in Vegas a 370z may run closer to high 13's but at sea level where cars are usually tested, it will run low 13's all day long. At a good track at sea level the 370z is good for 13.2-13.3 on average with some people even hitting 13.1.
So just because you don't see it happen in Vegas doesn't mean that it doesn't happen in other places. My old 06 LS2 Vette would only run 13.5 (on stock run flats), does that mean that LS2 Vettes only run mid 13's? Hell no, everyone knows they are good for 12.7-12.9 in stock form. My Camaro SS should run 12.9-13.1 but does it run that here in Vegas? Nope, much slower.
As for the OP's question, your V6 Camaro will have to be made as fast as the V8 Camaro in order to run with a 370z. Personally, rather than putting all that money into the V6 it would just be cheaper and easier to trade your car in for a V8. Bolt on's on the SS will leave the 370z in the dust.
Z/Camaro is offline   Reply With Quote
Old 06-14-2013, 10:38 AM   #40
bowtieguyvegas
Yep that explains it, LVMS sucks, someone call and have them close the track down. 370Z
Old 06-14-2013, 11:54 AM   #41
evilstevie
Drives: Pontiac G8 GT
Every tested time I've seen for the 370z has been right around 13.4. So if they're running mid 13's at LVMS that would be about par for the course.
evilstevie is offline   Reply With Quote
Old 06-14-2013, 03:19 PM   #42
turbolvr321
turbolvr321's Avatar
Drives: 2013 Camaro SS
No stock 370 runs low 13 sec. here in vegas, maybe below sea level with a 30 mph wind
My buddies factory Z ran 13.3-13.7. His first time at the track. (he ran about 5 times)
Now he has a blower. lol. He hasnt been back since the FI though.
2013 Camaro SS 6M
2013 Harley Davidson Softail Slim
turbolvr321 is offline   Reply With Quote
