sjm autoprod
Old 06-11-2013, 03:07 PM   #1
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Drives: A 2016 Challenger R/T M6 STP
ELM327 Bluetooth OBDII Scanner with Torque app, then what?
Now that I have all the diagnostic information, what do I do with it?
1) Engine RPM
2) Calculated Load Value
3) Coolant Temperature
4) Fuel System Status
5) Vehicle Speed
6) Short Term Fuel Trim
7) Long Term Fuel Trim
8) Intake Manifold Pressure
9) Timing Advance
10) Intake Air Temperature
11) Air Flow Rate
12) Absolute Throttle Position
13) Oxygen sensor voltages/associated short term fuel trims
14) Fuel System status
15) Fuel Pressure
Is there a table I can use somewhere to compare them with?
Track Day Videos: http://www.youtube.com/user/mrgoodman2000/videos
Built #83817, Born January 18th, Christened June 11th 2010, Stolen October 3rd 2016.
Mikamaro is offline   Reply With Quote
Old 06-14-2013, 03:57 PM   #2
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
Look at it? What are you trying to accomplish?
I use mine to log spirited driving and draw the parameters on a map. I also use it to read/clear codes.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 06-14-2013, 08:22 PM   #3
Mikamaro
MikeNoMaro
Mikamaro's Avatar
I would like to compare my results with others a guess...
Old 06-14-2013, 08:27 PM   #4
thahemp
Geek
thahemp's Avatar
Do you think you have a problem? You should be able to find typical values for a lot of those parameters by searching the forum. I wouldn't noid out on it though if you don't think you have a problem. Always leads to enjoying your car less due to "perceived problems" .
Use it for fun until you have an issue, then it makes a nice diagnostic tool as well.
x = ~x
Old 06-14-2013, 09:35 PM   #5
Mikamaro
MikeNoMaro
Mikamaro's Avatar
[/QUOTE]Use it for fun until you have an issue, then it makes a nice diagnostic tool as well.[/QUOTE]
Yes, I guess thats whats it for...thanks
Old 06-14-2013, 09:50 PM   #6
thahemp
Geek
thahemp's Avatar
No problem bud.
x = ~x
Old 06-14-2013, 11:00 PM   #7
meshamey
Meshamey
meshamey's Avatar
Drives: 2011 Camaro 2SS / 2014 Camaro ZL1
Hey I just bought 1 of those, Newegg had it on sale for $9.00. Could not pass up it up.
meshamey is offline   Reply With Quote
Old 07-02-2013, 11:28 PM   #8
JEFF75645
Drives: his wife crazy buying mods
I also just bought the ELM 327 Bluetooth OBDII and downloaded the app. I know it should be pretty easy to understand but can you make changes. I know some of you have a better grasp of it since it been around a while. Beside checking codes what else can it be used for? Maybe there needs to be a dedicated thread so ppl can exchange info and ask questions.
I really want to use it to log runs but have several questions.
Gone But Not Forgotten
JEFF75645 is offline   Reply With Quote
Old 07-02-2013, 11:39 PM   #9
thahemp
Geek
thahemp's Avatar
Start a thread. I'll answer everything i know the answer to!
x = ~x
Old 07-02-2013, 11:44 PM   #10
thahemp
Geek
thahemp's Avatar
Actually this one isn't titled too bad. What do you want to know?
x = ~x
Old 07-02-2013, 11:46 PM   #11
JEFF75645
Since I don't have the OBDII in my hands yet(will be delivered tmo).
But how do you retrieve results from data logging? Do you set your own parameters?
Sorry hemp but I got 12 hr at work to waste.lol.
I really just want to hit the ground running when I get this device.
Old 07-02-2013, 11:56 PM   #12
thahemp
Geek
thahemp's Avatar
Yep. You can choose any parameter that is recognized, which honestly, is pretty much everything. The logs are saved as an excel spreadsheet. I'm not sure if there is a graphical viewer or not? I'll see what I can find.
The app gauges work the same way. You choose the type and size of gauge you want, then you can assign any parameter to any gauge and plant it on a desktop. Placing things works a lot like android works. Home screens and all.
x = ~x
Old 07-03-2013, 12:01 AM   #13
JEFF75645
Thanks man. I guess I will play around with it before work tomorrow. Surely I will have a few more questions.
Will these logs be something my tuner can look at and make changes. The same he would run with HPTuners. Basically does this device offer good accurate info for him to make adjustments if needed?
Old 07-03-2013, 12:06 AM   #14
thahemp
Geek
thahemp's Avatar
Just to test that I tried to open the .csv file in LiveLink (SCT logging software) and it wouldn't open it. CSV is just a generic "comma separated values" file. Your tuner could use the tables to make changes, but he'll have to look at them as a spreadsheet. That's not something tuners are unfamiliar with. It's better than having no data at all!
x = ~x
