Booooosted.
Can a bad oil pressure sensor shut down the car?
So Bonnie went to get us lunch here at the office. While she was driving the oil pressure 'dropped' and had the flashing light and code that said the oil pressure was low and to shut the car off.
The car was running fine. The oil pressure reads low but doesn't seem low. No oil leaking other than the very light oil I get from the rear and that's always been there. I have had a cel that reads oil pressure sensor. Haven't had the chance to remove the blower and replace the sensor. The question is ......... Can the sensor being bad shut the car down thinking the oil pressure is that low when it really isn't? |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
No, are you hearing metallic noises?
Booooosted.
NO noises.
Do you have the center console 4 pack gauges? If so, what Oil Presssure reading do you get there?
note: just re-read your post. You said it dropped and then now reads low - that answers my first question. My worry would be how do you know for certain the sensor is bad. If its not the sensor then running it could be disastrous to state the obvious.
2010 Camaro 2SS Cam/Headers/CAI/3.91 gears 476 rwhp/440 rwtq (sold) |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS - Black - GFX Join Date: Nov 2008
stock oil pump?
Ordered: 10-13-08
Built: 3-30-09 (#1691) Recieved: 6-12-09 Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods. |
#6 | |
Booooosted.
The sensor has been on the cel for about a month. But has read fine on the gauge. |
#7 |
Booooosted.
#8 |
Booooosted.
I should ammend the OP.
The car never shut down. Nor did it stutter or do anything at all out of normal. It just gave the warning. |
#9 |
V8 Lounge member #2
I'd change that sensor ASAP bud.
#10 |
Booooosted.
Oh ya. This weekend.
Just sucks cause I have to pull the supercharger. |
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: the 2nd amendment home Join Date: May 2008
Bad oil pressure sensor on my truck will put me on the shoulder shut down...
Are you getting a good swing on the needle from idle to rev?
-- Benjamin Franklin lib·er·ty /ˈlibərdē/ noun 1. the state of being free within society from oppressive restrictions imposed by authority on one's way of life, behavior, or political views |
#12 |
replace the pump if it gave you a warning light i think that is nothing to do with sensor what was the presure for the last week weeks when sensor was giving you the cel
#13 |
Booooosted.
Yes. It does swing up when I rev it.
#14 |
Booooosted.
The last month since the cel was coming on it was around 30 psi.
