BeckyD @ James Martin Chevy
Old 06-12-2013, 04:55 PM   #1
Ravener
Ravener's Avatar
Drives: 2010 2SS RS M6 Blk
Plans for LS3 rebuild
Hi Guys, so I'm still sitting on my hands waiting for the verdict from the machine shop regarding forensics on my poor LS3 . Paying for a rental for weeks on end...hurts like hell.
Whatever the outcome, I need to think about next steps. I've been mulling over a 418 stroker build given that the whole damn thing is apart anyways...seems like a good excuse to do some heavy modification. Another thought is that I should just get it back together with a blower cam and think about going the whipple route. The thought of continuously sinking money into this thing irks the hell out of me. For pure cost effectiveness it's hard to gauge as a well built 418 can tangle with 600ish hp...and a SC can achieve the same.
Thoughts?
418 LS3, custom cam, tuned vararam, ported tb, Kooks stepped LT's, Kooks Hi-Flo cats and 2.5" street sleeper cat back, 18% UDP, crap stock rear tire size 12.03 @ 117 mph.
Ravener is offline   Reply With Quote
Old 06-12-2013, 05:15 PM   #2
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
I think you're going to need a high CR 418 to get anywhere close to 600 RWHP N/A. I'd be curious to know what combinations of pistons and milling people have done to get there.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 06-12-2013, 05:41 PM   #3
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
NA will require those TFs heads, a well built 416, fast 102/102, -xx valve relieved pistons for a nice big cam.
On a mustang dyno I'm 545 on a dyno jet about ~595 with my set up. I'd have more if I could afford those tfs's lol.
Old 06-12-2013, 05:42 PM   #4
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
What happened to your engine?
Old 06-12-2013, 05:53 PM   #5
thahemp
Geek
thahemp's Avatar
Did you put in -xx dished pistons or did you flycut the pistons? Let's say someone wanted to get around 12.5:1 CR. The 4" stroke gets you quite a ways. Where do you get the extra compression if you mill 0.0xx from the heads, then turn around and take 10cc out of the piston for PTV clearance? We need more details Mr. high CR! I have been pondering this lately too OP.
x = ~x
Old 06-12-2013, 06:28 PM   #6
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Lol well there's 2 compressions dynamic and static.
To achieve your desired compression you have to pick a piston and cam together as a whole.
With my 4.0 stroke and 65cc chambers and GM Mls gaskets and -2 cc valve reliefs and 4.0705 bore I have a 12 to one.
You can't go as far as -10 that's more of a dished piston for FI.
Old 06-12-2013, 06:28 PM   #7
KCS
KCS's Avatar
Drives: 2000 Pontiac Trans Am
For 12.5:1, you would could run something like Wiseco's K448X7
5cc domed piston and just cut a little off the deck of the heads.
KCS is offline   Reply With Quote
Old 06-12-2013, 06:31 PM   #8
Ravener
Ravener's Avatar
My engine is apart after the "lifter fiasco" referenced in my other threads. Still an ongoing headache. Car has been apart for 3 weeks...I'm still waiting to get word on condition of block and an idea as to why things failed. I've seen some of the more robust 416/418 builds noted for having 620/585...though spending the coin for the uber heads and intakes may be a bit down the line in the future. Maybe it's better to go the FI route and be content for now.
Old 06-12-2013, 06:31 PM   #9
thahemp
Geek
thahemp's Avatar
I guess I had never looked at pics of the domed pistons. They're valve-relieved too. Cool. That clears some stuff up in my head. Thanks.
x = ~x
Old 06-12-2013, 06:32 PM   #10
thahemp
Geek
thahemp's Avatar
Nah don't give up! That's why I was asking those questions. A little head milling and domed pistons is no big deal. Pretty sure litle is right around 12.5:1... that's why I chose that example .
x = ~x
Old 06-12-2013, 06:35 PM   #11
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
I said -xx because there are lots of possibilities you can go with. But not that drastic. With my -2cc I still had lots of Ptv clearance and I knew I should if gone bigger.
Here's a pic for reference
Old 06-12-2013, 06:38 PM   #12
thahemp
Geek
thahemp's Avatar
Yup. There's 2 more quarters worth! You must have gone home instead of big that day.
x = ~x
Old 06-12-2013, 07:09 PM   #13
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Lol
Here's a good place to get info.
http://www.wallaceracing.com/cr_test2.php
Old 06-12-2013, 07:46 PM   #14
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Yea I remember now!
Next time use morel/lunati lifters bud along with more phosphate/zinc in your oil. Good set of BTR springs set up correctly and correctly measures pushrods. Not that you didn't do it the first time. But I hope it turns out better bud.
