Solo Performance
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 06-13-2013, 02:25 PM   #1
axnhose
axnhose's Avatar
Drives: 2013 ZL1
Does your ZL1 sit to high in the front??
Wondering how I can get the front of my ZL1 to sit just a little lower. I know altering the height affects the magnetic shocks, so how do I lower it even 1/2 inch without screwing up the ride?
axnhose is offline   Reply With Quote
Old 06-13-2013, 03:01 PM   #2
KKreme15
KKreme15's Avatar
Drives: C6 Z06
i think pedders has a lowering kit that won't mess with the ride height sensors
KKreme15 is offline   Reply With Quote
Old 06-13-2013, 03:12 PM   #3
HDRDTD
Be carefull just how much ground clearance you end up with. If you still have the front winglets on the car, they hang down another 1 1/2 below the already low chin splitter.
HDRDTD is online now   Reply With Quote
Old 06-13-2013, 03:15 PM   #4
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
You can use Pfadt lowering springs without any problems. We put a buddies ZL1 on them a few weeks ago and it looks great.
Old 06-25-2013, 12:20 PM   #5
Z51Stingray
Livin' the Dream
Z51Stingray's Avatar
Drives: '14 Z51 Stingray, '16 Malibu LT
Are the transport spacers still in the front springs? They should have been removed before delivery and put inside the glovebox for you.
If they are, jack it up and pull them out. This drops the front a good inch.
Z51Stingray is offline   Reply With Quote
Old 06-25-2013, 01:34 PM   #6
kmthor00
Drives: 2013 ZL1 Black
This has been reported on here a lot lately! Ask me how I know?
kmthor00 is offline   Reply With Quote
Old 06-25-2013, 01:46 PM   #7
Z51Stingray
Livin' the Dream
OK, how do you know?
Old 06-25-2013, 02:54 PM   #8
kmthor00
Car was sitting high I thought, ride was not bad really, researched on this site, went out to garage & found bright yellow spacers still installed!
Old 06-25-2013, 10:59 PM   #9
axnhose
axnhose's Avatar
Drives: 2013 ZL1
Thanks kmthor00!!
That's what I was hoping to hear from someone on this site. I'm gonna go check it out and let you know.
Stay tuned!!
Old 06-27-2013, 01:08 AM   #10
axnhose
axnhose's Avatar
Drives: 2013 ZL1
Yellow spacer
I just got done removing the front wheel and took a good look at my front spring. I did not notice a yellow spacer in the spring so the dealer must have removed them. I also did not see them in my glove box either, so they must have kept them as well. I did notice a yellow rubber spacer at the very top of the spring, but it appears that is not removable.
Any other ideas on how to lower the front of the car without altering the ride, or affecting the magnetic shocks?
Old 06-27-2013, 10:53 AM   #11
kmthor00
Yours have been taken out, I would ask dealer for a set in case you ever have to tow/ship the car. I have read instances on here where dealer threw them out & had to replace. As for ride height now, sorry I can't help. Good luck,
Old 06-27-2013, 11:17 AM   #12
Matt@510
Drives: c6 vette cam & full bolt-ons
The Pfadt lowering springs work great. they dont affect the shocks. the ride does not become harsh and ultra rigid. very good way to go to make the car handle a little better and look alot better.
Matt@510 is offline   Reply With Quote
Old 06-27-2013, 10:11 PM   #13
axnhose
axnhose's Avatar
Drives: 2013 ZL1
Matt at 510,
I think I will try the lowered springs, and see how they look. Is the install difficult, and what is involved?
Old 06-28-2013, 09:33 AM   #14
Matt@510
Matt at 510,
install is fairly simple, dosnt really require any special tools. you will probably want to take the front struts to a shop to have them safely remove and install the new springs (most places about $50)
all in all a 6 pack and a few hours no problem to change out all four springs.
of course alot quicker if you have access to a lift.
