Old 06-13-2013, 04:15 PM   #1
Gtkilrss
Gtkilrss's Avatar
Drives: 2016 SS
Need help. Cammed ls3 sputtering
Ok guys it's an auto 2012 ss.
Last week did the lingenfelter vvt dod delete
Night fury cam
Lunati dual springs
7.425 pushrods
Pacesetter longtubes
3500 circle d converter
Had a miss fixed a ground and new plugs wires went away
Dyno tuned 445/435 rwhp
Everything went good for 2 days then developed a miss once again now it sputters from about 2500 rpm up.
Throws a p219a code and also had a o2 sensor code and I just replaced the o2 sensors.
All grounds look good
I just can't figure it out. Thought mayb somebody on here had mayb had the same problem.
When it sputters it almost acts like its drowning in fuel but my A/F stays in mid to high 12s
Gtkilrss is offline   Reply With Quote
Old 06-13-2013, 05:19 PM   #2
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
Looked up the code: "...a rich or lean cylinder to cylinder air/fuel ratio imbalance..." Would be an issue with the left bank. Left bank sensor could be detecting lean and sending signal to run rich at sporadic times. Not sure exactly why, but thought this might help. I would start by checking for cable damage to the left o2 at this point...maybe they are grounding out.
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 06-13-2013, 05:24 PM   #3
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Who tuned? It might be running a lil lean?
Old 06-13-2013, 05:25 PM   #4
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
I'd stop getting on it and get a better tune.
Old 06-13-2013, 05:38 PM   #5
Gtkilrss
Gtkilrss's Avatar
Drives: 2016 SS
I had local tuner that had tuned it when it was stock do it on the dyno. I have a wideband and can keep an eye on the a/f and it bounces everywhere now from 12.5-13.8 I know lean. It ran fine for 2 days after it got tuned. I'm almost leaning forwards an injector?
Old 06-13-2013, 05:38 PM   #6
Gtkilrss
Gtkilrss's Avatar
Drives: 2016 SS
Btw my wideband bung is in the left pipe right after the collector also
Old 06-13-2013, 05:44 PM   #7
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
Injector was the first thing I thought too. I have no logical explanation to back that initial reaction up though!
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 06-13-2013, 06:15 PM   #8
Gtkilrss
Gtkilrss's Avatar
Drives: 2016 SS
I just talked to well respected engine builder/friend and he said I need to pull valve covers thinks I have a rocker arm that's backed off
Old 06-13-2013, 11:08 PM   #9
thahemp
Geek
thahemp's Avatar
Did you do that yet? I checked under both valve covers on my lunch break the other day. It takes no time at all.
x = ~x
Old 06-14-2013, 02:07 AM   #10
Gtkilrss
Gtkilrss's Avatar
Drives: 2016 SS
Rockers are ok. No pinched wires. Gonna change plugs in the mornin again
Old 06-14-2013, 12:44 PM   #11
Gtkilrss
Gtkilrss's Avatar
Drives: 2016 SS
Changed plugs again and gapped them at .028 instead of .035 and cars running without a hiccup
Old 06-14-2013, 01:49 PM   #12
thahemp
Geek
thahemp's Avatar
Seems like an awful short gap. Are you sure your wires and coils are good? I wouldn't think at your levels you should have any problems with the .035 - .040 gap.
x = ~x
Old 06-14-2013, 03:26 PM   #13
Gtkilrss
Gtkilrss's Avatar
Drives: 2016 SS
Coils are good swapped out another set just to see. Brand new msd 8.5 mm wires
Old 06-14-2013, 05:08 PM   #14
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
I'm with thehemp I think the gap is a Lil too narrow.
