Old 06-13-2013, 08:17 PM   #1
nicecamaro
Drives: 2011 Camaro ss/rs
An effective mod???
Since the new hoods are effective for engine bay cooling, was thinking how to get a little more cooling on my '11 ss ; so I took off the rear hood seal, just pull's right off, now I have a 3/8" space between hood & cowl, has anybody tried this for better cooling ? Can't see why this wouldn't work a little, cool in from front & heat out the rear!
nicecamaro is offline   Reply With Quote
Old 06-14-2013, 01:26 AM   #2
3rdgen3
10-bolt Destroyer
3rdgen3's Avatar
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M
That will work to get heat out, however when it rains, now lots and lots of water is going to go into your engine bay and get lots of things wet.
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq
3rdgen3 is offline   Reply With Quote
Old 06-14-2013, 08:40 PM   #3
nicecamaro
No, there is an almost a 1" high ridge that the rubber seal sat on, all the way over to each fender where the water would have to run to, then down on the inner fender & to the ground. Thanks for the heads up, I didn't think of that about the water till I checked it out.
Old 06-19-2013, 07:46 AM   #4
BudMC77
BudMC77's Avatar
Drives: 2011 Camaro 1LT
Any update whether this helps?
Sent from my iPhone
BudMC77 is offline   Reply With Quote
Old 06-19-2013, 09:57 AM   #5
f5journal
Senior Camaro Fanatic
f5journal's Avatar
Drives: 2011 SS/RS manual - White
i'M INTERESTED IN MORE DISCUSSION HERE TOO...
Former '68 and '69 Z/28 Owner...........Now sporting around in a 2011 RS/SS with........Kooks LT's and cats, JRE tune, CAI, scoop, ZL1 Bumper conversion, custom ZL-1 grille, halo harness, Painted silver stripes, GM GFX, black painted lower edge of skirts and rear bumper. MGW shifter.....and now a 3.91 1LE diff
f5journal is offline   Reply With Quote
Old 06-19-2013, 09:59 AM   #6
Dtrimpi87
Banned
Drives: 2010 2SS/RS A6 & 2011 1LT/RS
It also dumps the hot air straight into the suction for the cabin vent and a/c.
Dtrimpi87 is offline   Reply With Quote
Old 06-19-2013, 11:19 AM   #7
BudMC77
BudMC77's Avatar
It wouldn't be any different than a larger cowl, would it?
Sent from my iPhone
Old 06-21-2013, 09:25 PM   #8
911medic
911medic's Avatar
Drives: 2012 SIM 2LT/1970 Camaro
At speed, the base of the windshield is a high-pressure zone, hence the effectiveness of cowl-induction.
I'm not sure how much flow-through venting you're going to get under those conditions. At lower speeds, probably yes. At higher speeds, I think that "outflow" turns into an "inflow." How that will affect the cooling, I don't know.
If it was that simple and effective of a fix (and could save GM money by not putting the seals in place on every car), don't you think they would have done it?
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller
RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting
Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting
911medic is offline   Reply With Quote
Old 06-22-2013, 06:03 AM   #9
BudMC77
BudMC77's Avatar
They may have been influenced to keep it as its added "insurance" to keep water out of the engine bay and not worry about water damage in any fashion.
Sent from my iPhone
