sjm autoprod
Old 06-13-2013, 10:27 PM   #1
overhaulengines
overhaulengines's Avatar
Drives: Red 2SS/RS M6
tuners, looking for input
hi guys, just drop my ride off this morning at LG Motorsports getting the G6X3 camshaft installed
check out the base line runs, they are a little shaky, Anthony is checking it out and i know they will find the problem. but just looking to see what yall think if yall can guess what yall think it is. i let yall know more tomorrow once they start doing runs after the cam is installed
NOTE: these run are before any work has started.
thanks for the input
lupe
overhaulengines is offline   Reply With Quote
Old 06-15-2013, 03:44 AM   #2
45thCAMARO 2SS/RS
xquest91x
45thCAMARO 2SS/RS's Avatar
Drives: 2012 45th Anniversary 2SS/RS
What do you have on it?
45thCAMARO 2SS/RS is offline   Reply With Quote
Old 06-15-2013, 10:41 AM   #3
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
What was the smoothing setting on the dyno. The less smoothing the higher the number will be an the lines will be rough. Most use smoothing 5 on dynojets.
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
http://www.gwatneyperformance.com/
ryan@gogwatney.com jzajac@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
Old 06-15-2013, 11:02 AM   #4
overhaulengines
Hi the smooth setting is 3, this is the dyno run after the cam install.
Old 06-15-2013, 12:33 PM   #5
Rhino79
Rhino79's Avatar
Looks good, the smoothing factor can help the graph lines look better, but looks like your making some good power now.
Old 06-15-2013, 11:34 PM   #6
overhaulengines
so you dont think the shaky lines are of any concern????
another thing we had to anthony had to really work to get to 460, when he usually gets 470-478 average.
i have the lg velocity CAI, kooks 1 7/8 headers and cats, then cat back corsa exhaust.
thanks
lupe
Old 06-16-2013, 01:54 AM   #7
Rhino79
Rhino79's Avatar
I think the shaky lines are from the smoothing factor. If afr and spark is good, its making all it will make.
Old 06-17-2013, 09:54 PM   #8
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
I like using the smoothing factor of 5. Yes it shows a lower max HP number but its more true.
You can do a smoothing factor of 1-3 can gain 10 RWHP because the reading is going to read off a valley or peak not a "smooth average". 5 is just more truer.
Like I tell the owners of the cars I calibrate, The dyno graph means less to me that what my scanner data is reporting how the vehicle is performance.
The illusion of high dyno numbers makes business for shops. To me, Its all about ethics how much fun and how safe I can make your car so it will last.
Tampa Tuning is offline   Reply With Quote
Old 07-01-2013, 09:17 AM   #9
Lethal Racing
Lethal Racing's Avatar
Drives: LSx Performance Specialist
Should put the smoothing on 5. That will look better. If the graph still looks that way then there is something going on.
Lethal Racing is offline   Reply With Quote
