Solo Performance
Old 06-14-2013, 09:45 PM   #1
tanur420
Drives: 2011 Camaro SS
hex vents
anyone running them without the splash trays? wondering if the trays essential as I would imagine heat would vent faster without them
tanur420 is offline   Reply With Quote
Old 06-14-2013, 09:49 PM   #2
Supercharged SS
Drives: 2010 Camaro
Yes, I've had the vents installed since June of last year with no trays. I've had the car in wicked rain storms for hours on end with no problems. You are correct, the heat escapes much faster without the trays.
Once you set the tray studs up its only a minute to throw on the trays.
Old 06-14-2013, 10:29 PM   #3
tanur420
do you need to use the motor cover with no trays? I havent had the cover on it in over. year..really not sure where it is lol
Old 06-14-2013, 10:50 PM   #4
Glen e
Glen e's Avatar
Drives: Garnet 2LT RS
I want these vents bad but have all sorts of tree crap where I live...any ideas how to keep that stuff out of the vents?
Glen e is online now   Reply With Quote
Old 06-15-2013, 01:08 AM   #5
StephenS_84
Drives: 2011 2SS/RS
"Tree crap" doesn't really explain anything. The vents come with mesh, so if it's leaves you're referring to then that will keep that kind of "tree crap" out.
StephenS_84 is offline   Reply With Quote
Old 06-15-2013, 10:18 AM   #6
Glen e
Glen e's Avatar
I talked to steve....I know it comes with mesh....tree crap is not leaves....forget it...I'll work with steve..
Old 06-15-2013, 11:06 AM   #7
The 2010 Sin
Dont H8 Me Cuz U Aint Me
The 2010 Sin's Avatar
Drives: 2016 SS Sedan, 2017 Explorer Sport
hex vents for the win
The 2010 Sin is offline   Reply With Quote
Old 06-15-2013, 11:16 AM   #8
StephenS_84
Drives: 2011 2SS/RS
Old 08-19-2013, 06:49 PM   #9
Lee123
Lee123's Avatar
Drives: 2012 2SS M6
What holds the black insulating blanket tight against the hood when you don't use the trays? I'm seriously thinking about having them installed if I can find anyone in Phoenix to do it, but I don't need the splash pans and was planning to leave them off. I saw a thread where they were planning to make a trim ring for the inside that would hold the blanket up, but they scrapped the idea and went with modified splash pans.
2012 2SS Convertible
Magnuson, Headers, Cam, JRE Tune. 563 HP.
Lee123 is offline   Reply With Quote
Old 08-19-2013, 06:56 PM   #10
Glen e
Glen e's Avatar
the threaded holes for the pans could be used as threaded studs with rod and then two black alum bars across the studs would hold the blanket back up against the hood...very easy mod--also a bead of hi heat silicone could be used...
Old 08-19-2013, 07:04 PM   #11
CamaroI
Drives: 2010 IOM Camaro
I live in Texas and have been running with the Trays in place for over a year without any heat issues
CamaroI is offline   Reply With Quote
