Old 06-14-2013, 10:18 PM   #1
Chad 2012 RS
Chad 2012 RS's Avatar
Drives: 2012 Convertible 2LT/RS
Tonneau attatchment....
At a Loss..... Can't find where the bands hook up to on the rear back seat panel. I found a rear facing barb on the folding mechanism that kind of line up on each side to hook it too, but nothing on the back seat rear panel.
Chad 2012 RS is offline   Reply With Quote
Old 06-14-2013, 10:22 PM   #2
heymatt
heymatt's Avatar
Drives: 2012 IBM 2SS Vert.
Most times they didn't get installed at the dealership. They're probably in a bag waiting to be installed!
Found mine rolling around in the trunk!
LS3/M6 K&N, VMAX throttle body, RX Catch Can, skip shift eliminator, DT shorties and Solo HFC, DRL harness and 5K LED DRL, ZL1 rear sway, 1LE front sway
heymatt is offline   Reply With Quote
Old 06-14-2013, 10:22 PM   #3
Michael Rophone
Michael Rophone's Avatar
Drives: Yes
The two posts (B) for the 2012 are installed by the dealer.
Or in your case, not.
They should be in an envelope, either in the trunk or the glove box.
You're in Moore. Did they blow away? (too soon?)
Michael Rophone is offline   Reply With Quote
Old 06-14-2013, 10:34 PM   #4
Chad 2012 RS
Thanks for the quick response guys!!
Found these in the glove box. Assuming this is it? If so do I have to remove something to install it? Top up? Top down? To install....
Old 06-14-2013, 10:37 PM   #5
Chad 2012 RS
Michael,
Yes, I'm in Moore, an no, not too soon. A sense of humor is needed! I faired ok. House/yard covered in what I can best describe as Tornado Snot. A 1/4 mile away, not so much. Veteran's Memorial park neighborhoods leveled.
Old 06-14-2013, 10:39 PM   #6
heymatt
heymatt's Avatar
Top down. I popped the trim pieces on the sides above the back seat windows. You need to reach behind to attach the nut to the bolt. It's tight! Don't forget to use the spacers. Some use a larger washer to make sure the band doesn't slip over the bolt head.
Old 06-14-2013, 10:43 PM   #7
Chad 2012 RS
Thanks!!!!
Old 06-14-2013, 10:50 PM   #8
Chad 2012 RS
Is anyone familiar with the 'barb' I found by feel on each side in the general area of the tonneau cover cords?
Old 06-14-2013, 10:58 PM   #9
Michael Rophone
Drives: Yes
Michael,
Those are the bad boys. Installing them is easiest with the top down.
Glad you are safe Chad.
Old 06-14-2013, 11:07 PM   #10
Chad 2012 RS
Thanks Michael! Do I have to remove one of the plastic panel fasteners to allow installment of the tonneau cord holders? I cant find an open place to install.
Old 06-14-2013, 11:08 PM   #11
Chad 2012 RS
..... Crap. Thought I was on facebook and could 'Like' your pic, Hahaha
Old 06-14-2013, 11:20 PM   #12
Michael Rophone
Drives: Yes
heymatt is your go-to guy. The dealer installed my posts, so I'm clueless.
Old 06-14-2013, 11:24 PM   #13
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
Drives: 16 Encore, 07 G6, 99 Astro, 16 VW
The dealer should have installed the attachment posts before delivery. I would take it back and have them put them on.
The Bird is the word!
Old 06-14-2013, 11:28 PM   #14
Chad 2012 RS
Angrybird,
I bought the car at a dealer 175 miles away and I'm concerned a 'local' dealer won't give me the same priority as someone who bought from them. I know it works that way with boats....
