Solo Performance
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > ZL1 Engine, Exhaust, and Bolt-Ons
Old 06-15-2013, 04:15 AM   #1
OHIO SPEED
Ohio-Speed.com
OHIO SPEED's Avatar
Drives: 2010 1LT v6 Twin Turbo
ZL1 Chevy Camaro Heat Exchanger (Black Unit) 80283PROB for SALE
OHIO SPEED Now offers the ZL1 Chevy Camaro Heat Exchanger (Black Unit) 80283PROB
OEM Finish also available.
With 3 times the coolant capacity over the stock unit, stand on the skinny pedal with confidence - no heat soak here!
This design features dual pass construction and dual 10” SPAL electric fans that result in reduced coolant temperature by up to 25°F. The wiring harness features heavy gauge wiring, dual relays and dual fuse holders that deliver continuous service without fail. This unit comes complete with detailed full color instructions that guide you through the installation in a mere 2 hours (avg).
Every heat exchanger is 100% TIG welded using the latest in core technology (no epoxy like other brands) for superior performance and long life. When you start with the superior components, the finished product outperforms all others!
FEATURES & BENEFITS
Up to 25 degree coolant temperature drop over O.E. heat exchanger
Dual 10”SPAL fans for extreme cooling - no heat soak
Double pass design for maximum heat transfer
Heavy duty wiring harness features dual relays and dual fuse holders
3 times the coolant capacity vs. stock heat exchanger
All mounting hardware included
Also available in O.E. appearing BLACK finish for additional cooling efficiency
This Unit is a Black Version!! Standard unit shown and is available.
PM FOR PRICING!!
Performance Parts and Show Car Accessories
Website: http://ohio-speed.com/default.aspx
Email: ohiospeed2010camaro@windstream.net
Phone:440-813-2490
OHIO SPEED is offline   Reply With Quote
cooling, heat exchanger, zl1 camaro
