Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
sjm autoprod
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Other Generations > 4th Generation Camaros
Old 06-15-2013, 01:54 PM   #1
Drives: V8 permagrin
Catch can
Are these a good idea for 4th gen LS engines or just something for newer Camaros.
roorback is offline   Reply With Quote
Old 06-15-2013, 04:18 PM   #2
All internal combustion 4 stroke engines benefit. You don't ever want oil ingetion in the intake air charge.
Old 06-15-2013, 06:10 PM   #3
Gunning for Sixth
Zabo's Avatar
Drives: '03 ZR2 Blazer
Just make sure you route it correctly through the PCV system, otherwise all that oil can feed right into the intake and overpressureize the crank case. If you're lucky in a case like that you'll just be burning off excess oil for a year from all reaches of your exhaust. :/
I'd save up and do the following BEFORE a catch can:
LS6 intake
LS6 valley cover
LS6 PCV system
THEN do the can.. and mount it to the left cylinder head (looking towards the back of the car), not the body. Once the PCV system is altered the can can go directly in it's place.
Zabo is offline   Reply With Quote
Old 06-28-2013, 09:07 AM   #4
Butter Bar!
xXSilencerXx's Avatar
Drives: 2011 SS, 1998 Trans Am
Get the can from WS6 store and then do the LS6 conversion if you really want it. While the LS6 setup is better and it's what I have on my car, it still allows oil to pass through. The catch can is the best solution.
2011 Camaro SS, White/Orange, LSR Short Throw, CAI
1998 Trans Am, Red, H/C/I, 3200 CircleD Stall, full suspension
2004 GSXR 1k, Matt Mladin Edition
xXSilencerXx is offline   Reply With Quote
