Cold Air Inductions
Old 06-15-2013, 07:46 PM   #1
tanur420
Drives: 2011 Camaro SS
electric water pump
are there any other options besides meziere? anyone running these have any problems?
also dont think itd be an issue but im running a 25% underdrive pulley, would the pump be to much for the alternator since its turning slower?
tanur420 is offline   Reply With Quote
Old 06-15-2013, 08:01 PM   #2
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
You'll be ok with th UD pulley. Meziere street will be your best choice unless you are only going to be racing at the 1/4 then the race version is for you.
Old 06-15-2013, 10:07 PM   #3
Nightmare2012
come find out;)
Drives: stockish 2012 camaro ss
Whats the gains on such upgrade?
Nightmare2012 is offline   Reply With Quote
Old 06-15-2013, 10:56 PM   #4
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Some say 5 others 10 others but you can leave in on while at the track for cool off.
Old 06-16-2013, 01:18 AM   #5
Nightmare2012
come find out;)
is it really worth the 800+ though?
Old 06-16-2013, 01:22 AM   #6
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
That's kinda like the fast debate. Sure it will help but like the heads and intake, dollar per hp is a steep price
Rhino79 is offline   Reply With Quote
Old 06-16-2013, 01:38 AM   #7
BlaqWhole
BlaqWhole's Avatar
Drives: 2010 Camaro 2SS/RS LS3
It is not worth half that price. Whatever extra power over a pulley is not worth the extra $600...you can find used pulleys for around $150. Not to mention that if it goes bad one day, and it will go bad one day, you will be stuck where you are. And god-forbid you're driving and don't notice your temps going up. My advice if you get it, make sure you wire it correctly, keep extra fuses with you, and monitor your temps constantly. But I'd pass on that if I were you.
Nadia (2010 Camaro 2SS/RS LS3) - Vararam CAI - SLP Underdrive Pulley - V-Max TB and Power Wedge - OBX 1-7/8 LTs with HF Cats - OBX 3" Cat-Back - Custom Tune - BER Ported Intake Manifold!!
Amy (2015 Mustang GT Premium convertible manual trans) - GT350 IM/TB - Airaid Tuned cai - MBRP Race 3 inch catback - Custom tune!!
Veronica (2013 Jeep Grand Cherokee Overland 5.7 Hemi) - Bone stock
Saving the world...1 hp at a time!!
BlaqWhole is offline   Reply With Quote
Old 06-16-2013, 06:44 AM   #8
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
I see you point but when your at a point where you have all boltons and then some and are trying to squeeeeeze a Lil more out then lots turn to the EWP. They don't burn out like that they last a good while.
Old 06-16-2013, 09:07 AM   #9
tanur420
Would a ls3 pump be usable on l99? i know something about the gasket being different but could it work? most places seem to only carry the ls3 model
Old 06-16-2013, 09:15 AM   #10
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
They should be the same pump. Don't see how it would be different. Ls1/Ls2/Ls3 are the same gasket.
Old 06-16-2013, 09:57 AM   #11
Rhino79
Rhino79's Avatar
The ls3 Mezeire pump is the same but the l99 Mezeire gives u the clearance you need in between the different front cover and the pump.
Old 06-16-2013, 10:41 AM   #12
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Thanks Ryne for that info.
Old 06-16-2013, 11:39 AM   #13
Rhino79
Rhino79's Avatar
The pump is the same, the l99 kit has some spacers I believe.
Old 06-16-2013, 03:15 PM   #14
tanur420
so I could use the ls3 kit on my l99 would just need to find some spacers?
