Old 06-15-2013, 06:58 PM   #1
bluBlud
bluBlud's Avatar
Drives: 2013 2SS/RS/1LE
How hot should the engine bay get?
The thread about the recent C5 fire got me thinking about how much hotter the engine bay in my 1LE seems to get compared to my truck and wife's car, and how much longer it retains heat. For example, the car has been parked for almost 2hours in 75F air after a 40 minute drive at normal highway/town conditions and I can't comfortably leave my hand on anything in the engine bay for more than a second or two. So, I was wondering if anyone has ever measured engine bay temps on theirs. I found the link below... not from a C5 but maybe somewhat relevant.
http://www.z06vette.com/forums/f5/wh...-reach-113545/
bluBlud is offline   Reply With Quote
Old 06-15-2013, 07:01 PM   #2
forklord
forklord's Avatar
Drives: 2010 2SS
Hex hood vents and ceramic coat your headers if theyre stainless. two best things you can do to reduce engine bay temps
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
forklord is offline   Reply With Quote
Old 06-15-2013, 07:20 PM   #3
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
I had a 1979 jeep CJ-5 that was like that, you couldn't even pull the dipstick out because the handle was so hot. I put one of the aluminum billet oil caps on my 2010 and it got so hot I couldn't touch it either after the car got to temperature.
I wonder if my TL1 hood insert helps much.
The Bird is the word!
Old 06-15-2013, 08:44 PM   #4
SteelCamaro
Drives: 2012 2SS LS3
Mine is the same way. I don't know specific temperatures, but I believe it was designed that way on purpose so the car doesn't need as much time to "warm up" if you choose to go out again only a short time after your previous drive. BMWs are designed this way as well.
SteelCamaro is offline   Reply With Quote
Old 06-16-2013, 02:16 AM   #5
3rdgen3
10-bolt Destroyer
3rdgen3's Avatar
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M
Not exactly. Its inherent to the design of the car. Air forced through the rad, makes hotter air blow onto the engine/engine bay and then the pull-fans do it even more. Aluminum block and heads also lets more heat dissipate faster in the engine bay too. The problem is without hood vents or some sort of extractor, theirs a lot of excess heat. The excess heat soaks into your intake tract and that slows the car down as hotter air is less dense and therefore you'll make less power
Contrary to that though, engines run best when they are hot. The hotter the more efficient (up until a point obviously).
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq
3rdgen3 is offline   Reply With Quote
Old 06-16-2013, 03:12 AM   #6
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
right. Hot(operating temp) engine, cold air, best combo
Old 06-16-2013, 05:39 AM   #7
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Your panicking.
Old 06-16-2013, 09:19 AM   #8
pannhead51
pannhead51's Avatar
Drives: 2SS convertible
No heat-soak here. I have the TL1 hood insert and removed the drip tray. Heat pours out like a flood ..also when I get home after 90+ temps I pop the hood.
pannhead51 is offline   Reply With Quote
Old 06-16-2013, 10:52 AM   #9
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Drives: 2010 LS3 2SS
There are plenty of things to obsess over ... This is not one of them
Mchlgrrsn is offline   Reply With Quote
Old 06-16-2013, 10:57 AM   #10
Ryanbabz71
Ryanbabz71's Avatar
Drives: 2018 Hyper Blue 1SS 1LE
I was thinking about this last night. Went for a drive got home and the car sat for 30-45 min. I then went to check my oil and I couldn't touch the dipstick (billet not stick) without a rag.
The heat was still radiating from the engine bay. Next time I will hit it with a temp fun
Ryan
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic
Car Build: http://www.camaro6.com/forums/showth...0#post10049680
Old 06-18-2013, 01:02 AM   #11
BLACK10
BLACK10's Avatar
We work on just as many vettes as we do camaros(which is a lot!). Vettes have a much higher problem with heat due to the design. Less air flow through the engine bay, the opening is much more restrictive.
Just adding headers to a vette will sometimes cause heating issues. Luckily the camaro is not as a sensitive. Coating the headers as well as a fan adjustment helps out greatly.
Old 06-18-2013, 01:50 AM   #12
Liam
Tampa Bay Camaros
Liam's Avatar
Drives: 2016 Camaro 2SS, Hyper Blue
As long as it doesn't get as hot as The Stig's you should be fine.
(Too soon?)
Liam is offline   Reply With Quote
Old 06-18-2013, 05:22 AM   #13
omgitsmikeyC
Drives: 2014 CTS-V- totalled/ 45TH ss- SOLD
Silly question, but is this why people go to the 160 thermostat, or is that for soemthing else?
2014 CTS-V... with some go-fast bits coming
omgitsmikeyC is offline   Reply With Quote
Old 06-18-2013, 05:43 AM   #14
ToolFan66
ToolFan66's Avatar
Drives: 2011 2SS 6.2L W/RS package
I pop the hood on my car, after a good drive. Don't ask me why, I just do it.. LOL!!
KooKs LT Headers, Borla S-Type cat back, RotoFab CAI, Bo White PTB, RMCR tune...
ToolFan66 is offline   Reply With Quote
