BORLA
Old 06-15-2013, 09:01 PM   #1
73vette
73vette's Avatar
Drives: 2010 Camaro LS, 1973 Corvette
Dyno, do these #'s look right?
Does my dyno look normal? I thought I would be putting down a little more power.. Best run was 224rwhp, 231rwtq.
I have a 2010 LS A6, vararam, resonator delete, and magna flow mufflers.
Humidity 54% but it just finished raining.
80 degrees (F)
STD: 1.06
28.95 in-Hg
4th gear
73vette is offline   Reply With Quote
Old 06-15-2013, 09:07 PM   #2
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
Something isn't right, your tq is more than your hp..
Sent from my SAMSUNG Galaxy S III using telekinesis.
BaylorCamaro is offline   Reply With Quote
Old 06-15-2013, 09:29 PM   #3
73vette
73vette's Avatar
That and I thought it should be a little higher. Lol! I also didnt think that our 3.6l should pull higher torque than hp.. Too small displacement.
Old 06-15-2013, 10:04 PM   #4
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Just replied to the other thread.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 06-15-2013, 10:11 PM   #5
The Stig
knows 2 facts about ducks
The Stig's Avatar
Also the graph is really rough - should be a smooth line.
Click to view my build thread
Old 06-15-2013, 10:15 PM   #6
73vette
73vette's Avatar
Thanks guys! Stig, what happened?!
Old 06-16-2013, 12:50 AM   #7
The Stig
The Stig's Avatar
Engine fire that wasn't caught in time - totaled her.
Old 06-16-2013, 08:17 AM   #8
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
That looks abysmally low. Stock auto should put out around 255, stock manual around 265. Mods may not add much over that. Try another dyno.
DarkneSS is offline   Reply With Quote
Old 06-16-2013, 08:47 AM   #9
Maxspeed
~COTW 6/30/14~
Maxspeed's Avatar
Drives: 2011 Camaro SS/RS
Mine kind of looked like that and it was detonation.
Mods: Heritage Grill, Blade Spoiler, Corrado Hoodliner Mural, Premium Engine Boxes, Radiator Shroud, Custom Painted Bowties, Dipstick & Engine Caps, RX Catch Can, Corsa cat back exhaust, CAI black powder coat cold air, Apex cold air intake scoop and Apex washer tank relocate kit, Dynatech SuperMAXX Ceramic Coated LT Headers, High Flow Cats, JRE470 Rough Idle Cam Package, DSS 1,000 RWHP Axels, Slowhawk Mustang Dyno Tune, QTP QTEC 66 Low Profile Cutouts and iTSX. 453 RWHP 427 RWTQ
WEB LINKS
BUILD
TIMING CHAIN FAILURE
TRANSITION FROM STOCK TO CAM VID
Maxspeed is offline   Reply With Quote
Old 06-16-2013, 09:11 AM   #10
GretchenGotGrowl
The smooting is at only 3 when most use 5, so that may explain some of the roughness. I saw the dip around 4200 on my LLT a few times. I think it was pulling timing, probably because of the knock sensors. It was really hard to tell without being able to see the logs.
Old 06-16-2013, 11:15 AM   #11
Scooter11
Scooter11's Avatar
Drives: 2013 SW 2LS
Otherwise that's just plain depressing for the rest of us V6ers
Scooter11 is offline   Reply With Quote
Old 06-16-2013, 12:42 PM   #12
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Drives: 2011 2LT/RS Camaro IOM
OP if it makes you feel any better I had my car dynoed at a show and the highest I got in 3 runs was 217rwhp. They kept insisting I run my car in 5th gear and they set the speed limit to 100 so the car barely got to 5k rpms. Tried telling them to do it in 3rd and raise the speed limit but they would listen. Luckily I only wasted $25. They later said "If you add another 20% that will give you the right number". Guess that is what happens when you let a bunch of college students majoring in automotive be in charge of a dyno.
kjkjr27 is offline   Reply With Quote
