BeckyD@RodgersChevrolet
Old 06-15-2013, 09:04 PM   #1
RolltideSS
RolltideSS's Avatar
Drives: 2011 2SS/RS Vert
Spark plug question
Hey everyone,
I just had headers and a tune done a couple weeks ago and after starting my car yesterday I had a service stabilitrack warning come up and not go away. After reading a few threads it seems like spark plugs are the most likely culprit. I am having a heck of a time figuring out how to check them though. On the v6 they sit on top but it looks like I would need to jack up the car to check them on an l99? Is this correct? If not, how can I get to them to see if they are good? Sorry for the apparently dumb questions but your assistance would be appreciated.
RolltideSS is offline   Reply With Quote
Old 06-15-2013, 09:31 PM   #2
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
Drives: 2010 Camaro SS
Most likely a loose wire on the V8.
LSX Camaro is offline   Reply With Quote
Old 06-15-2013, 09:43 PM   #3
RolltideSS
RolltideSS's Avatar
Thank you! I went ahead and checked all the wires and one of them slid on quite a bit more. Took it for a short gentle drive and no error. I am assuming if it were a spark plug it would still show the error.
On a side note if anyone could tell me how to get to the spark plugs I would appreciate it just for my own personal knowledge.
Old 06-15-2013, 10:49 PM   #4
LSX Camaro
LSX Camaro's Avatar
What do you mean getting to the spark plugs? The wires pull off and the plugs are there. Simple socket, ratchet and extension will get the job done.
Old 06-15-2013, 10:54 PM   #5
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
Roll tide
Old 06-16-2013, 08:26 AM   #6
RJT-SS
RJT-SS's Avatar
Drives: '11 2SS/RS A6
You can get to the plugs from the engine compartment. The passenger side takes a little effort because of the A/C lines but it isn't too bad. The driver's side is VERY easy.
Performance Mods:
Kooks 1-7/8 LTs; Calico coated w/HFCs, Solo Mach XL catback w/J-pipes, VMax TB, C.A.I. Intake, JRE Tune, RX Catch-Can
RJT-SS is offline   Reply With Quote
Old 06-16-2013, 09:05 AM   #7
RolltideSS
RolltideSS's Avatar
Hey - so just to check my understanding if I pull off the end of the wire that runs down between the headers the spark plugs are right there? Sorry this has to be broken down to the most basic level but I didn't grow up in a family that ever even lifted the hood so I'm still learning even some of the most basic parts of auto maintenance.
Old 06-16-2013, 09:15 AM   #8
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1951 Mercury
Right you the plug wires go from your coils up top to the spark plugs. When the wires are fully seated you should be able to feel that. Did you have any other work done?
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 06-16-2013, 09:23 AM   #9
RolltideSS
RolltideSS's Avatar
Nope, right now it's just headers, exhaust, and tune. That'll be as far as it goes until next year.
Old 06-16-2013, 07:25 PM   #10
RJT-SS
RJT-SS's Avatar
It sounds like your wires may have been the problem as you said you are now ok. Another common problem with spark plugs and header installs is that some people do not remove the plugs to do the install. It is not necessary to remove them but, since they are made of ceramic, they can crack if hit by the stock manifold during removal or the header during installation. The symptom of a cracked plug is similar to what you originally described. The only way to check for a cracked plug is to remove each plug and visually inspect the white ceramic part. If it is cracked, the crack usually appears as a dark line.
To remove the plugs, use a 5/8" spark plug socket. It is a deep socket that has a rubber insert in it to grab and hold the tip of the plug. This helps to keep the plug from falling out of the socket (and cracking) after it is fully un-threaded.
When installing plugs, some folks like to put some anti-seize compound on the threads to make future plug removal easier. However, it is not necessary. The torque spec for the plugs is 11 ft lbs but most people do not use a torque wrench. When you tighten a spark plug, you can feel a definite "stop" as you make the final tightening turns. There is no need to over tighten.
Hope this info helps your understanding a little better.
Performance Mods:
Old 06-17-2013, 02:04 PM   #11
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
Roll Tide +2
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
Old 06-22-2013, 07:33 PM   #12
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
I just started having this same issue. I had the headers installed about 200 miles ago and now I am noticing that at a stop my car feels like it is chugging, at about 4k RPM the exhaust crackles, doesn't feel like the performance is all there, and then I just got a Service Stability Track. I believe the guy who installed the headers pulled out every plug to insure he didn't crack them. Im just wondering why 200 miles later am I having these issues? I think the first thing I will do is check to make sure all the wires are snapped into place. If they are all seated correctly then I guess I will be pulling out all the plugs. :(
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, RX CC, GFX, Subs, Tuned by Rhino79 at GPI.
rberns is offline   Reply With Quote
Old 06-22-2013, 07:39 PM   #13
MARINE1991
MARINE1991's Avatar
Drives: COTW 8/29/11 2010 CAMARO
You may have the same issue I had the extension o2 wires got burnt
MARINE1991 is offline   Reply With Quote
Old 06-22-2013, 07:44 PM   #14
rberns
rberns's Avatar
Are you talking from the cats? How much did that run for replacements. I know the installer used zip ties to keep the O2 extenders pulled back and away from the headers.
