BeckyD @ James Martin Chevy
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Old 08-25-2013, 03:50 PM   #15
Elvis
Elvis is Camaro,s name
Elvis's Avatar
Drives: 2010 Camaro 2SS/RS SIM L99 Auto
Battery tenders
Originally Posted by babaron View Post
So I read a story about a battery explosion from being left on a tender and now I'm afraid use either of my 2 tenders.
I use the Schumacher $20 tenders from Advanced Auto. Do I need to worry and how do I prevent an explosion?
Thanks!!
Ron
Who has the specifics on this battery explosion, please share the facts with us.
Elvis
Elvis is offline   Reply With Quote
Old 08-25-2013, 04:05 PM   #16
AWSME SS
AWSME SS's Avatar
Drives: 2015 Cummins
I use them all the time, no problems at all even after several months of continuos connection to battery.
AWSME SS is offline   Reply With Quote
Old 08-25-2013, 04:22 PM   #17
Elvis
Elvis's Avatar
I also use deltran junior Automatic tender.....no issue to date.......was looking to find the Facts on the issue mentioned in this thread.
Elvis
Old 09-30-2013, 12:00 AM   #18
moserbe
moserbe's Avatar
Drives: 2012 Camaro SS
I've been using them for many years with no issues.
moserbe is offline   Reply With Quote
Old 10-07-2013, 06:40 PM   #19
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
For the past 15 years I have friends that store exotics for clients. 150+ per winter. They require every single car to have a Battery Tender brand tender on them and have never had any issues.
Old 10-20-2013, 09:53 PM   #20
haynes
haynes's Avatar
Drives: 2014 Camaro 2 SS convertible
If you use a battery tender attached to the battery, is it neccesary to disconnect the battery from the car? I would prefer not to so I don't reset anything in the spring
2014 Camaro 2SS/RSConvertible
Crystal Red Clearcoat/ Solo Exhaust/ Powder Coated Calipers/ Replica ZL1 Rims
haynes is offline   Reply With Quote
Old 10-20-2013, 10:42 PM   #21
joeybsyc
joeybsyc's Avatar
Drives: 2010 Aqua Blue Metallic 2SS
No. Don't disconnect anything. I clip mine on the ground post on the leading edge of the driver's front fender, and one on the positive jump post underhood, plug the tender in the wall. I have never even seen my actual battery, and it stays 100% charged all winter with zero issues. BTW, My car is a 2010, and has been done this way every winter.
joeybsyc is offline   Reply With Quote
Old 10-29-2013, 09:30 PM   #22
camaro500
camaro500's Avatar
Drives: 2017 Jaguar F Type R
Use noco 3500
JRE cammed w.full bolt ons 444rwhp/422rwtq SOLD
''Life moves pretty fast. If you don't stop and look around once in a while, you could miss it.'' - F. Bueller
camaro500 is offline   Reply With Quote
Old 10-29-2013, 10:44 PM   #23
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
I wonder if guys are hooking them up to the battery, or the front engine bay positive post and a ground
Ive used them for 10 years without a problem
Tampa Tuning is offline   Reply With Quote
Old 10-29-2013, 11:58 PM   #24
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
I don't know about battery tenders, but I have known people that had batteries explode with a trickle charger. Charging a battery can release small amounts of hydrogen gas. They had the battery in a confined space that allowed the hydrogen to build up. Then they disconnected the charger cables while the charger was still on. The resulting spark ignited the gas and caused a small explosion. Luckily no major damage or injury.
Mark114 is online now   Reply With Quote
Old 10-30-2013, 06:48 PM   #25
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
I use positive post and engine block for a ground. Just a better charge for me.
Old 10-30-2013, 06:53 PM   #26
midnighter
Drives: nothing
I have had one on my Camaro since 2010 and it has never had any issues.
Old 10-31-2013, 12:44 PM   #27
Jose
Jose's Avatar
Drives: 2010 Camaro 2SS/RS White S/C
So, I use it and plug it in directly to the battery, is this correct, or should I tie it to the engine positive and ground?
"It does not matter if you win or loose, what matters is if I win" Carl Fogarty
Jose is offline   Reply With Quote
Old 10-31-2013, 03:37 PM   #28
wakespeak
wakespeak's Avatar
Drives: 2013 2SS LS3/NPP
Batteries produce hydrogen when being charged. The engine can build up fuel fumes. The key is to avoid sparks and let things air out before connecting or disconnecting. Charge the battery fully, then hook the tender up before you plug it in to avoid sparks. Mine has a 10 amp and 2 amp setting. The 2 amp is the "tender" setting and is safer.
Make sure you use a tender and NOT a trickle charger. Tenders will cycle off when the battery is fully charged.
You can Google examples of tenders causing fires and I don't leave a tender on our boat. I am most concerned with the tender getting yanked by someone and sparking as it is pulled. I pull the batteries and charge them in the garage or just charge them in the spring as our winter is short. The AGM batteries don't seem to mind being neglected.
wakespeak is offline   Reply With Quote
