ADM PERFORMANCE
Old 06-16-2013, 05:11 PM   #1
5th_GEN_SS
Junkie
5th_GEN_SS's Avatar
Drives: SIM 2SS/RS M6
New car maintenance- fluid changes; oil, rear differential, etc.
I know there are a billion and one different posts about changing fluids, I went through this four years ago.. Now I have a new 2013 1LE and and trying to remember what I learned back then about the break in.
At what milage interval do you recommend the first fluid changes?
What is everyone using?
Thanks
"Letty" Murdered out 2013 Camaro 1LE. (Old car SIM 2010 2SS/RS)
5th_GEN_SS is offline   Reply With Quote
Old 06-16-2013, 08:24 PM   #2
Chubby
Drives: Busted
So wait, you sold your super special SS???
Chubby is offline   Reply With Quote
Old 06-16-2013, 09:32 PM   #3
5th_GEN_SS
Junkie
5th_GEN_SS's Avatar
It was special and yes I traded, I have a 13' 1LE now.
Old 06-16-2013, 09:34 PM   #4
tonyko1
Banned
Drives: 2012 Camaro 2SS/RS Convertible, IBM
I want a 14 Z28 with the 427 motor. That and a new 14 Vette, vert.
As for your fluid changes, who cares, you will be trading up soon, ha.
tonyko1 is offline   Reply With Quote
Old 06-17-2013, 08:35 AM   #5
Chubby
Drives: Busted
Just make sure you keep the garage door closed all winter. Don't want don't stray salt dust particles getting on it.
Old 06-17-2013, 03:06 PM   #6
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Thanks
You could check the manual. It says how early you should change it.
If however you don't want to;
- at 500 miles change the oil.
- at 1,500 change the oil again and the rear diff fluid.
- after this follow the normal change interval. Everyone changes their oil at different times but the trans fluid and rear diff should be changed every 25k if you drive hard.
