AAC Style
Old 06-16-2013, 06:53 PM   #1
heymatt
heymatt's Avatar
Drives: 2012 IBM 2SS Vert.
Charging question
Just got back from a long trip, 6 hrs total.
I noticed at highway speed the volt gauge hangs around 12 volts. While at lower speeds, say under 40 mph it hangs around 14 volts.
Air on, Iphone plugged in to usb and gps plugged in.
Sound normal? Didn't seem to change if I unplugged the gps. Runs fine no other symptons.
LS3/M6 K&N, VMAX throttle body, RX Catch Can, skip shift eliminator, DT shorties and Solo HFC, DRL harness and 5K LED DRL, ZL1 rear sway, 1LE front sway
heymatt is offline   Reply With Quote
Old 06-16-2013, 06:56 PM   #2
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
Normal.
Sent from my 2SS/RS
FSP tuned: 377/389
Old 06-16-2013, 06:57 PM   #3
Jason RS
2011 Summit White V6 RS
Jason RS's Avatar
Drives: 2011 Summit White V6 RS MRT 1.0
Normal
Jason RS is offline   Reply With Quote
Old 06-16-2013, 07:25 PM   #4
Cheveey57
Cheveey57's Avatar
Drives: 2010 Camaro 2LT RS
Normal chillax
If you're not living on the edge, you're taking up too much space.
Cheveey57 is offline   Reply With Quote
Old 06-16-2013, 07:41 PM   #5
jd10013
Drives: 2012 camaro
it's normal. under certain conditions the alternator turns itself off to improve fuel efficiency. kind of freaked me out the first time I noticed it too. was on vacation 600 miles away and noticed the voltage dropping from 14 something till it got down to about 12.2. thought either the battery or alternator was going.
jd10013 is offline   Reply With Quote
Old 06-16-2013, 08:07 PM   #6
Medic726
Medic726's Avatar
Drives: 2017 Camaro RS Auto
I just had the same discussion because I installed a radar detector that had a low voltage warning and it kept kicking on. I ended up turning that option off since the voltage bounced up and down so much.
Medic726 is offline   Reply With Quote
Old 06-16-2013, 08:38 PM   #7
heymatt
heymatt's Avatar
Not stressed over it, just seemed odd. Running fine, starts fine, all electrical good. Just after 11k miles never really noticed it.
Cool, thanks all for the quick responses!
