JUICEDMOTORSPORTS
Old 06-16-2013, 09:15 PM   #1
NipTuckTaxi
NipTuckTaxi's Avatar
Drives: 2010 Camaro 1SS
ls3 pistons in l99
Anyone made this change for a bit more compression.? May be going in to check, change piston rings soon. May change l99 to ls3 pistons if its possible.
2010 SS: ERL 416; AGP TT; Century Super 6L80; Strange S60. Supporting mods in between. 650rwhp\ 700 rwtq.
NipTuckTaxi is offline   Reply With Quote
Old 06-16-2013, 09:23 PM   #2
JEFF75645
Drives: his wife crazy buying mods
Im also interested in this.
Gone But Not Forgotten
JEFF75645 is offline   Reply With Quote
Old 06-16-2013, 09:25 PM   #3
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
It would be alot easier and less expensive to just have the heads milled for the desired compression.
Old 06-16-2013, 09:34 PM   #4
keith102371
Drives: 2000 SS
to answer your question, Yes they will work, only difference is the ls3 is flat top and l99 has valve releifs. Same bore size and same rings.
keith102371 is offline   Reply With Quote
Old 06-16-2013, 09:43 PM   #5
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
Id keep the l99s to give you more exhaust valve clearance and just mill heads.
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
http://www.gwatneyperformance.com/
ryan@gogwatney.com jzajac@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
Old 06-16-2013, 09:44 PM   #6
SPCBA
Drives: pleather and Chiclets
wcch will work your heads into magic...the l99 pistons are there for a reason
SPCBA is offline   Reply With Quote
Old 06-16-2013, 10:08 PM   #7
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Yup!! Best thing to do. If your willing to swap pistons swap to a forged one not another hyperexplosive piston. Just saying.
Old 06-16-2013, 10:16 PM   #8
JEFF75645
I think, and I could be wrong, but I was quoted somewhere around $150 to mill the heads. Since the porting had already been done.
Old 06-17-2013, 12:06 AM   #9
VADER SS L99
Thats good because thats alot less inexpensive and easier than new pistons.
