Old 07-05-2009, 07:42 PM   #43
camaroguy
MJ is finally home!
camaroguy's Avatar
Drives: 2010 CGM 2SS/RS Camaro M6
Originally Posted by speeflo View Post
excuse this question of its stupid but is this something that will happen to all cars sooner or later? ive dumped the clutch quite a few times at over 4krpms with traction control on in comp mode or everything off and havent had a issue yet should i be ok or No? maybe done it 15 times or so
Well, I'm not one to say since I don't work for GM, but I would say chances are greater if one was to dump clutches/launch control/burnouts on a continued basis. How many launches you can get before it breaks? but eventually something is going to wear out and / or break. Just sucks that it happened to break on me the first time I tried launch control. Hopefully I will be getting the car back tomorrow.
I'll tell ya.. I am scared to death to try another launch control with it. Maybe I will stick to rolling starts instead..
Another thing, I did do a couple burnouts a couple days before the launch control, and when I would dump the clutch, I would always get a very noticeable "Thud" noise coming from either the tranny or rear end. Probably the output shaft cracking at the time....
camaroguy is offline   Reply With Quote
Old 07-05-2009, 10:03 PM   #44
speeflo
Drives: Chevy 2500
well call me stupid but . IM FURIOUS took the car out for supper stopped at stop sigh revved the car to about 3500-4k then dumped clutch and thud broken car ..im very mad i hope they have a fix/upgrade for it cause if the car does it again after repair i dont know what ill doo..
speeflo is offline   Reply With Quote
Old 07-05-2009, 10:09 PM   #45
camaroguy
MJ is finally home!
camaroguy's Avatar
What vin is your camaro?
Old 07-05-2009, 10:23 PM   #46
speeflo
Drives: Chevy 2500
ill let ya know when i get home i just dropped it off at dealer
Old 07-05-2009, 11:33 PM   #47
wyocamaro
wyocamaro's Avatar
Drives: 2010 2SS/RS, 2-2007 Silverados
Originally Posted by UCF w00t View Post
It's not the fault of launch control, it's a problem with the output shaft of cars built in the mid 16thousands.
http://www.camaro5.com/forums/showthread.php?t=29895
http://www.camaro5.com/forums/showth...383#post634383
http://www.camaro5.com/forums/showthread.php?t=29989
GM is aware of the problem and apparently re-routed some cars to Detroit to get fixed after build but before delivery. Hopefully they get you a new transmission soon.
This makes #4 I believe, all built very close to each other.
Thanks as always for keeping things in check andgrounded with reality.
2SS/RS, Sunroof, IOM Inside and out, Manual.......VIN 7754. 5000: DELIVERED 5/18/09
wyocamaro is offline   Reply With Quote
Old 07-05-2009, 11:39 PM   #48
speeflo
Drives: Chevy 2500
mine is vin # 13070
Old 07-06-2009, 11:11 AM   #49
Embalmer
2G1FT1EWXA9103351
Embalmer's Avatar
Drives: 2SS RS, SIM, 6pd, 20"Alum
Originally Posted by Rallyman6 View Post
I did a launch with the Comp mode on and the clutch wouldn't return at all until I stopped. Clutch slipped like hell.
We have self-adjusting clutches - Went to my dealer and there was a service bulletin for the C6 Corvette's / Same tranny.. Nothing for the Camaro, tranny seems fine now.
They wrote an RO on it to keep in history.
Same exact thing happened to me the first time I tried launch control. Clutch got stuck half way and wouldn't return.
Burned the clutch nicely....fortunately no permanent damage (that I know of).
Embalmer is offline   Reply With Quote
Old 07-06-2009, 12:40 PM   #50
outlawz
outlawz's Avatar
Drives: 1995 Camaro Z28 Drag car
okay guys first off don't take this the wrong way but I drag race competitively, I have an NHRA competition license and i have been doing it for close to 15 years...
GM putting a "launch control" in these cars was dumb IMO. I know it's there but dumping your clutch at 4,000 rpm's is just plain asking for trouble even without sticky tires.. You are going to get better acceleration slipping the clutch than straight dumping it until you get some serious hardware underneath it and a much better clutch. People are going to be frying clutches left and right. Are clutches warrantied items? Last time i checked they werent cause they are wear/tear items.....
honestly stop using that stupid crap. I GUARANTEE GM will not include the launch control for the 2011 camaro cause it's gonna cost them more money in the long run fixing broke cars....
outlawz is offline   Reply With Quote
Old 07-06-2009, 03:50 PM   #51
camaro5's Avatar
Drives: 2019 Louis Chevrolet Camaro
Originally Posted by slowerthanu View Post
Wow, you took this from a discussion on the strength of the Tremec to a discussion on the morals and responsibility of the new auto owner.
They put launch control on the car, I'm sure as hell gonna try it.
V8 Camaros are supposed to freakin MELT their rear tires daily.
This is a metallurgic failure. Not driver error. It would break with or without launch control.
Originally Posted by TopoSpain View Post
Hello guys,
This problem with the transmission is only with V8 and manual trans or with V6 or automatic ones too?
V8 only. Breaking trannys and rear cv joints it seems...
The idea of NOT doing burnouts in a Camaro SS is stupid. GM has a problem.
mine is vin # 13070
So much for a limited VIN range for failures...
They will break with or without launch control.
This is metallugy problem like the Toyota Tundra's V8 camshafts that broke at the beginning of production.
Awww Snap!!
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP Graduate, A.S. Automotive Technology, Telecommunications Specialist, CISCO Certified Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to,
any warranty of merchantability or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 07-06-2009, 04:24 PM   #52
camaroguy
MJ is finally home!
camaroguy's Avatar
Originally Posted by camaro5 View Post
V
Yeah, I'm going to go pick her up in about an hour. They just got done replacing the tranny. Service guy says that the output shaft wasn't properly hardened and the new one should be fine.. Hope so!
Old 07-06-2009, 11:20 PM   #53
speeflo
Drives: Chevy 2500
i sure hope they fix the issue with a upgrade part and no more problems
Old 07-07-2009, 02:24 AM   #54
camaro5's Avatar
Good info. So the failing parts were not hardened properly.
Only good thing I can find here is it sounds like they've identified the cause, and should be able to permanently rectify the situation.
Keep watching here...
STANDARD DISCLAIMER
Old 07-07-2009, 04:02 AM   #55
gotpball44
Boost Is Your Friend
gotpball44's Avatar
Drives: 2016 Hyper Blue 1SS Camaro
Send a message via AIM to gotpball44
There should be a recall on all these tranny problems. Is there a way to alert GM of all these tranny probs, so they could start looking into it?
gotpball44 is offline   Reply With Quote
Old 07-07-2009, 07:22 AM   #56
2SSJIM
2SSJIM's Avatar
Drives: 2012 CRT ZL1 #1400
I would say they already know with several cars being fixed for the same issue!
2SSJIM is offline   Reply With Quote
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 89 02-20-2015 09:43 PM
2010 Camaro Pricing for Canada Announced garfin Camaro Price | Ordering | Tracking | Dealers Discussions 503 05-24-2009 05:59 PM
Excitement Builds for 2010 Chevrolet Camaro camaro5 5th Gen Camaro SS LS LT General Discussions 2 11-02-2008 02:54 AM
2010 Chevy Camaro to offer two V6s at launch; Z28 to trump SS? radz28 Camaro ZL1 Forum - ZL1 Specific Topics 51 06-23-2008 01:12 PM
