third_shift studios
Old 06-17-2013, 08:36 AM   #1
Big C CamaroSS
Drives: Black Camaro 2SS/RS 1LE
Beefed up drive train on 1LE?
I am on my way out to (hopefully) swing a deal on a black 2013 2SS/RS 1LE. I have been reading about the 1LE since 5:45am this morning. I know it has "beefed up" axles, and I think a beefier transmission than an SS. Is the drive shaft the same as the SS? I'm asking because I have a red Magnuson supercharger sitting in the spare bedroom waiting to be installed. Since I bought the supercharger, the concern for snapping an axle or the drive shaft has been in the back of my mind. If those are more heavy duty in the 1LE, I am vibrating with excitement over the thought of driving it supercharged!!!
BTW I can not believe the different/better features on the '13 1LE vs my 2010 SS! The 1LE sounds incredible ( I don't mean the exhaust, but I can imagine it sounds killer with the NPP and exhaust commander)
Big C CamaroSS is offline   Reply With Quote
Old 06-17-2013, 09:22 AM   #2
SWAG1LE
SWAG1LE's Avatar
Drives: 2013 1LE
Same driveshaft, same tranny just different ratio...There are several supercharged 1LE's on this forum...SUKXOST for example
Current: PFADT Drop Springs/ZL1 Rock Guards/SLP Skip Shift Elim./DRAKE Bowtie Delete/ELITE Catch Can/XPEL Clear Film/CORSA ZL1 Cat Back/Z28 CAI
SWAG1LE is offline   Reply With Quote
Old 06-17-2013, 09:51 AM   #3
2cnd chance
Too Many Great Choices
2cnd chance's Avatar
Drives: Grand Sport/Z07
The transmission is the same as found in the Z06.
2cnd chance is offline   Reply With Quote
Old 06-17-2013, 10:00 AM   #4
BDBiker
BDBiker's Avatar
Drives: Black 2013 2SS/RS 1LE
Good luck on the purchase, you will love the 1LE.
BDBiker is offline   Reply With Quote
Old 06-17-2013, 10:31 AM   #5
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
Not exactly... the Tremec used in the 1LE performance package also has some cooling as well as different gearing.
tramtwo is offline   Reply With Quote
Old 06-17-2013, 10:35 AM   #6
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
The only part of the 1LE axle that is "beefier" is the outer CV joint. Everything else including splines on both ends are the same. The diameter of the shafts the same. If you're SC-ing, I wouldn't get too excited that these will hold up much better than the stock SS. Avoid hard launches. I posted a thread with a picture showing the difference in size of the two axles' CVs. If you're interested just search for it.
bannonm is offline   Reply With Quote
Old 06-17-2013, 11:30 AM   #7
5.3Avalanche
Drives: '08 Silverado, '99 T/A WS6
Isn't the transmission the same as in the Z06?
'08 Silverado | GMPP Exhaust | Z60 Suspension
'99 Trans AM | Magnaflow Exhaust | WS6 Performance Package
5.3Avalanche is offline   Reply With Quote
Old 06-17-2013, 12:11 PM   #8
SWAG1LE
SWAG1LE's Avatar
Drives: 2013 1LE
No idea LOL...
but:
"Tremec TR6060-MM6 six-speed manual transmission. Combined with a numerically higher 3.91 final-drive ratio, the close-ratio gearing of the transmission is updated for road-racing performance. As with the ZL1, the 1LE transmission capabilities a standard air-to-liquid cooling system for track use."
http://www.carngebot.com/chevrolet-camaro-1le-2013.html#more-820
Old 06-17-2013, 12:18 PM   #9
SWAG1LE
SWAG1LE's Avatar
Drives: 2013 1LE
http://corvetteactioncenter.com/spec...008tr6060.html
The link above shows all the specs on the 1LE tranny which is the same as the Z06. Hmmm interesting I did not know that.
Old 06-17-2013, 12:48 PM   #10
Synner
Drives: not stock
the standard m6 has cooling too, its just no one seems to talk about it or realize it exists for some reason.
Old 06-17-2013, 02:40 PM   #11
Cody6.2
Drives: 2012 Camaro 2SS
Same gearing but not same transmission.
Cody6.2 is offline   Reply With Quote
Old 06-17-2013, 02:51 PM   #12
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
I think both cars have the MM6. I do believe they are the same.
gajagfan is offline   Reply With Quote
Old 06-17-2013, 04:38 PM   #13
PYROLYSIS
Remember the Charleston 9
PYROLYSIS's Avatar
No it doesn't. The engine oil cooler is standard but the standard manual trans on the SS does not have a liquid to liquid cooler like the 1LE.
Old 06-17-2013, 04:42 PM   #14
SWAG1LE
SWAG1LE's Avatar
Drives: 2013 1LE
Right...
"The Tremec TR6060-MM6 short-throw six-speed manual employs a sportier 3.91:1 final drive rather than the normal 3.45:1. Like in the ZL1, crisp shifts are had row after row, thanks to an air-to-liquid cooling system."
Read more: http://www.motortrend.com/roadtests/...#ixzz2WVo3QPWK
