Cold Air Inductions
Old 06-17-2013, 07:41 PM   #15
Big C CamaroSS
Drives: Black Camaro 2SS/RS 1LE
But the Z06 has the LS7 correct? And doesn't GM rate that for 505hp? So it should be able to handle 565-575hp from a supercharger as long as I don't BEAT THE LIVING SH*T out of it (and I don't plan to).
BTW I did buy it and it looks KILLER!!!! Pictures tomorrow hopefully.
Big C CamaroSS is offline   Reply With Quote
Old 06-17-2013, 08:03 PM   #16
BigBlock69RS
Ed
BigBlock69RS's Avatar
Drives: 2013 AGM Camaro 2SS/RS/1LE
Here is the complete list of changes for the 1le
  • close ratio manual transmission that has higher final drive (3.91 vs. 3.45)
  • air-to-liquid cooling system lifted from the ZL1 (trans and oil coolers)
  • 20-inch wheels covered in Goodyear Eagle Supercar G:2 tires, 285 on all 4 corners
  • Improved wheel bearings (zl1)
  • Improved toe links
  • upgraded sub-frame bushes
  • Better rear shock mounts
  • rear monotube shocks
  • thicker antiroll bars(27mm front, 28mm rear)
  • strut-tower bar
  • beefed up the rear-axle half-shafts
  • ZL1's high-capacity fuel pump and additional fuel pickups were also added to prevent fuel starvation in hard-cornering situations.
  • matte-black hood
  • functional front splitter
  • rear spoiler
  • Oil catch can
  • red Brembo brake calipers
  • ZL1's flat-bottom, microfiber-covered steering wheel
  • short shifter topped with a microfiber shift knob.
What beefed up axles shafts really are is anyone's guess, sounds like bannonm, measured them?
BigBlock69RS is offline   Reply With Quote
Old 06-17-2013, 08:24 PM   #17
joelster
Drives: '94 Z28+ '14 1LE
I thought it had front monotube shocks too?
'94 Z28, 414" LT1, 10.15 at 133.65 N/A pump gas
'14 1LE, NPP, 12.991 at 109.40
joelster is offline   Reply With Quote
Old 06-17-2013, 10:19 PM   #18
toehead93
Drives: 2014 2SS/1LE
No, fronts shocks are retuned stockers.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 06-19-2013, 08:17 AM   #19
Cody6.2
Drives: 2012 Camaro 2SS
Originally Posted by gajagfan View Post
I think both cars have the MM6. I do believe they are the same.
I'm just saying that they might have the same gear ratios and so on but are not the exact same transmission.
Cody6.2 is offline   Reply With Quote
Old 06-19-2013, 09:07 AM   #20
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
And what I am saying is that the two transmissions have the exact same part number, and thus I am saying they are the same part. Why are you saying they are not?
gajagfan is offline   Reply With Quote
Old 06-19-2013, 09:52 PM   #21
2cnd chance
Too Many Great Choices
2cnd chance's Avatar
Drives: Grand Sport/Z07
They're the same. Tremec MM6
2cnd chance is offline   Reply With Quote
Old 06-20-2013, 12:24 AM   #22
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
This happens a lot... don't bother.
tramtwo is offline   Reply With Quote
Old 06-20-2013, 08:03 AM   #23
davidcroft
Sellin Chevy's since '06
davidcroft's Avatar
Drives: 2014 SS sedan
I was under the impression they were ZL1
2018 MBM ZL1 6spd Coupe.
Current toy-02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub35K orig miles.
SOLD!'16 SS Sedan-Forgestars/ARH/rotofab
TRADED!2014 SS Sedan
SOLD! 2013 Blue Ray1SS/1LE 1of20.
TRADED! 2012 White 1SS/RS
davidcroft is offline   Reply With Quote
Old 06-20-2013, 08:56 AM   #24
Cody6.2
Well except for shift rod placement, reverse lockout solenoid location, bellhousing, tailshaft housing or lack there of, vent location. So in other words they're not the same and you cannot use one or the other as they're Camaro or Corvette specific.
Old 06-20-2013, 08:57 AM   #25
Cody6.2
Transmisson model number and RPO code designation are far from being the same part number.
Old 06-20-2013, 08:58 AM   #26
Cody6.2
Yep it's amazing how many people think they know it all because they read about in in the owners manual or on a website. Which is why so many of you get your panties in a bind when someone tells you the truth. It's one thing to make comments like this when I'm wrong but like the other debates I'm not. Given the tire debate was opinionated this is quite different as the two transmissions are not one in the same, period.
Old 06-20-2013, 12:20 PM   #27
gajagfan
gajagfan's Avatar
Well since it is always fun to learn, and I by no means have my panties in any type of a wad, what are the two part numbers? It might be useful to know if finding a replacement transmission for the Camaro ever comes into play.
Old 06-20-2013, 12:30 PM   #28
SWAG1LE
SWAG1LE's Avatar
Drives: 2013 1LE
No, they are 1LE specific. They do share the same bearings tho...although I have been known to be wrong at least once or twice lol
EDIT: This thread covers it...AXLE wise
http://www.camaro5.com/forums/showthread.php?t=260556
Current: PFADT Drop Springs/ZL1 Rock Guards/SLP Skip Shift Elim./DRAKE Bowtie Delete/ELITE Catch Can/XPEL Clear Film/CORSA ZL1 Cat Back/Z28 CAI
SWAG1LE is offline   Reply With Quote
