Old 06-20-2013, 12:51 PM   #29
Cody6.2
Drives: 2012 Camaro 2SS
Originally Posted by gajagfan View Post
Well since it is always fun to learn, and I by no means have my panties in any type of a wad, what are the two part numbers? It might be useful to know if finding a replacement transmission for the Camaro ever comes into play.
It doesn't matter what the actual part numbers are as they aren't interchangeable.
Cody6.2 is offline   Reply With Quote
Old 06-20-2013, 12:58 PM   #30
2cnd chance
Too Many Great Choices
2cnd chance's Avatar
Drives: Grand Sport/Z07
We understand the Camaro and Corvette bolt up differently, but the core transmission is the same. You're arguing semantics.
2cnd chance is offline   Reply With Quote
Old 06-20-2013, 01:18 PM   #31
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
It does. Lets say I found a great deal on a used MM6. It would be nice to know what the correct part number was for the 1LE vs the Vette. You seem to have that information. I am simply asking for the part numbers that you have so I can know for future reference. I was not able to find anything on line that gave the part numbers.
gajagfan is offline   Reply With Quote
Old 06-20-2013, 04:14 PM   #32
Cody6.2
I'm not arguing anything, you guys said they were the same thing and they aren't.
Old 06-20-2013, 04:19 PM   #33
Cody6.2
You can tell by looking at them.
Camaro = Side mounted reverse lockout solenoid with shifter point on top.
Vette = Top mounted reverse lockout solenoid with shifter in bellhousing
Camaro
Corvette
Old 06-20-2013, 04:28 PM   #34
2cnd chance
We understand the Camaro and Corvette bolt up differently, but the core transmission is the same. You're STILL arguing semantics.
See above.
Old 06-20-2013, 04:46 PM   #35
1977and2010
Tampa Gulf Coast Family
1977and2010's Avatar
Drives: 1977 Z28, 2SSRS 2010 M6
Originally Posted by PYROLYSIS View Post
No it doesn't. The engine oil cooler is standard but the standard manual trans on the SS does not have a liquid to liquid cooler like the 1LE.
Yes it does. I've had to disconnect mine twice. Once when I replaced my clutch. And once when I pulled the motor. Hell three times, also when I first put in a cam.
1977and2010 is offline   Reply With Quote
Old 06-20-2013, 06:11 PM   #36
aggieguy13
aggieguy13's Avatar
Drives: 2013 SS/RS VR 1LE
several wrong points on here.......
1le has the same Trans as ZL1, with closer gear ratios, and a higher final drive of 3.91 vs. the SS of 3.51
as well as the half shafts, toelinks, and wheel bearings straight from the zl1.
other parts include
-flat bottom "suede" steering wheel, shift knob/shift boot
- 28mm mono tube in the rear, 27mm in the front
-brembo 4-piston braking system with 26" and 24" rotors
-rims/tires/hoodwrap, front splitter, spoiler (duh)
-upgraded fuel pump based off of the Zl1's
i BELEIVE that is a complete list. could be missing
aggieguy13 is offline   Reply With Quote
Old 06-20-2013, 06:12 PM   #37
aggieguy13
aggieguy13's Avatar
the 1LE is an "Air-Liquid" system instead as thought to be more efficient, which is why it is the same as used in the ZL1
Old 06-20-2013, 06:20 PM   #38
2cnd chance
That's the first time I've heard that it is a ZL1 tranny with different ratios. Isn't it a 3.45 final drive in the SS?
Old 06-20-2013, 06:29 PM   #39
aggieguy13
aggieguy13's Avatar
im fairly sure its 3.51, but im no savant
Old 06-20-2013, 06:54 PM   #40
2cnd chance
Yes, but when stating information it's good to ensure its accuracy.
You know to ensure everything on the Internet is "true".
Old 06-20-2013, 07:23 PM   #41
aggieguy13
aggieguy13's Avatar
well i read in several different places it was 3.51.
but iv also read the 0-60 on a 1LE is only 4.7. which is hogwash
Old 06-20-2013, 09:26 PM   #42
Nick S
Nick S's Avatar
Drives: 2013 Camaro 1LE
See the link to the pdf found in this post. It has all the specs on gearing between the 1LE and the SS.
http://www.camaro5.com/forums/showpo...27&postcount=3
Nick S is online now   Reply With Quote
