Jason 98 TA
Old 06-17-2013, 11:29 AM   #1
E.T.
E.T.'s Avatar
Drives: 2012 Camaro 2SS/RS
Anyone install rear sway bar on ramps?
I've got a Pfadt ZL spec rear bar on the way and I'm wondering if the suspension should be loaded (rear wheels on ramps) or unloaded (rear on jack stands) for the install.
E.T. is offline   Reply With Quote
Old 06-17-2013, 11:41 AM   #2
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
Install them anyway you like. But when you torque the endlinks have the suspension loaded.
bannonm is offline   Reply With Quote
Old 06-17-2013, 11:47 AM   #3
E.T.
E.T.'s Avatar
Awesome. I just wasn't sure if I'd be able to get the stock one out without removing a wheel or something.
Old 06-17-2013, 09:10 PM   #4
heymatt
heymatt's Avatar
Drives: 2012 IBM 2SS Vert.
You'll be able to get the old one out with the wheels on. But... It will be easier putting the new one in with the wheels off. The new links tuck inside the rims, if you're doing ZL1 style.
LS3/M6 K&N, VMAX throttle body, RX Catch Can, skip shift eliminator, DT shorties and Solo HFC, DRL harness and 5K LED DRL, ZL1 rear sway, 1LE front sway
heymatt is offline   Reply With Quote
Old 06-17-2013, 09:59 PM   #5
E.T.
E.T.'s Avatar
Cool. I'll probably try it on ramps. Worst case, I can just jack it up and take off the wheels. It'll give me an excuse to use my impact wrench =)
Old 06-18-2013, 09:21 PM   #6
heymatt
heymatt's Avatar
The rear is considerably easier than the front.
Old 06-19-2013, 09:36 AM   #7
Synner
Drives: not stock
Bar installation doesn't matter. Adjustable endlinks should be set at ride height with wheels on and suspension loaded so the endlinks themselves have no preload.
Synner is online now   Reply With Quote
Old 06-19-2013, 11:30 AM   #8
caverman
caverman's Avatar
Drives: '69 SS Convertible
It's WAY easier to deal with the drop links with the wheels off. Not saying you can't do it with wheels on but you'll probably be cussing a lot more if you leave them on.
Build Journal
Old 06-23-2013, 06:16 PM   #9
jag107
jag107's Avatar
Drives: 2010 2SS/RS IOM M6
I just did an Eibach rear sway and links on ramps, it was easy, just had to pull the exhaust hangers off so I could squeeze the new bar in. Don't know how different the ZL bar is.
Placed order: 02.25.2010
Took delivery: 04.06.2010
Halltech Yellowjacket CAI, Mike Norris catch can, VMAX PTB, JBA Shorty headers Hi Flow cats & axleback, Magnaflow Tru X pipe, Eibach F&R sway bars & end links
jag107 is offline   Reply With Quote
