JDP Motorsports
Old 06-17-2013, 12:36 PM   #1
gtrain41
Drives: 2001 Chevrolet Corvette
* SOLD * 750+ HP Supercharged Forged LS7 INSTALLED!!!!
Unbelievable Price!!!!
Deal of a lifetime !!!!!! BRAND NEW ENGINE!!!
!NEW! 2010-2013 Camaro 427 Supercharger Engine Package with RED TVS 2300 Supercharger
!!$SOLD INSTALLED and custom DYNO TESTED/TUNED!!
or $SOLD + shipping, not installed
Over $8000 dollar savings, Deal of a lifetime! for a 700+HP 5th Gen Camaro!
ONLY 1 of these to sell, act now or regret forever,
Produces 700HP no Headers
Produces 750HP with Long Tube Headers
427 ci Gen IV LS7-based Aluminum Supercharged Long Block Engine Package. (Includes RED TVS 2300 Supercharger with 89 lbs/hr Injectors and proper pulley combination to produce 10 PSI of safe boost pressure)
This 427 engine is built from a NEW GM LS7 7.0L block, a 4.00" stroke Manley 4340 forged steel crank, 4.125" 2618 forged Manley aluminum pistons and 4340 forged Manley H-Beam Rods. It has SLP's 1.85 rocker-arm package, Comp Cams custom blower camshaft and custom built high flow LS3 cylinder head combination.
427 LS7 Aluminum Long Block Includes:
• Built entirely from brand new parts
• Sold outright, no cores required
• GM LS7 aluminum block
• 427-CID displacement
• 4.000 Manley 4340 forged steel crankshaft, balanced to rotating assembly
• 4.125" Manley 2618 forged alloy pistons
• 6.125" Manley 4340 forged steel H-beam rods
• Magnuson TVS2300Camaro Supercharger (w/custom pulley set to produce 10 psi of boost)
• Comp Cams Custom Blower Camshaft
• LS3 High Flow Built Cylinder Heads
• SLP 1.85 Rockers
• SLP Double Row Timing Chain Set
• FAST 89 lbs/hr Injectors
• FREE Custom Dyno Tune
• SLP 55001 Heavy-Duty Oil Pump
• New GM Lifters and Lifter Guides
• Hardened Pushrods
• ARP Cylinder head studs
• MLS Head Gaskets
• 10.82:1 compression ratio (nominal)
• 58 Tooth reluctor wheel
• Meticulously assembled to OEM tolerances and specifications
PM me for more details.
gtrain41 is offline   Reply With Quote
Old 06-17-2013, 01:06 PM   #2
San2cci
San2cci's Avatar
Drives: 2013 silver ice metallic ZL1
Wish I had the money!!! Where in NJ are you located? Is it a shop?
San2cci is offline   Reply With Quote
Old 06-17-2013, 01:48 PM   #3
gtrain41
I had the motor built to put in a '12, but ended up selling the car. Have a bunch of new parts for it that never even got put in. I personally will not be installing the engine, but paying for SLP in toms river to do it....I have some credit there I need to use up!
Old 06-19-2013, 09:10 AM   #4
gtrain41
As an FYI, if you are too far away and want to install it local to you, i can take off a $1000 and ship the engine to you. $13995 for 750+ HP!!! Insane deal!!!
Old 06-24-2013, 05:30 PM   #5
gtrain41
had a buyer fall though over the weekend so i have to bump it up
Old 06-24-2013, 07:30 PM   #6
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
Damn that's an awesome deal!
LS3, JRE Smooth Idle cam, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Spohn lcas, Whipple, LPE dual fuel pumps, Rx catch can, Id850s, Alky Control
BigMatt is offline   Reply With Quote
