Caryle Racing
Old 06-17-2013, 05:12 PM   #1
CBRpilot
CBRpilot's Avatar
Drives: 2012 SS
Stock manifolds, no cats, enough backpressure?
Only mods are CAI, resonator delete (x pipe in it's place), stock mufflers replaced with Borla XR-1's. I'm happy with the tone, but not with the volume. I've run this setup before on my 98 WS6 (cammed, LT's, ORX and bullet mufflers and dumped pre-axle) and the XR-1's sounded amazing. Do you guys think that stock manifolds with no cats will still provide enough backpressure to maintain most of my low-end torque?
I don't plan on EVER doing anything else other than LT's (50% chance of that in a year), and I want to maintain a decent bit of my low-end torque. My plan is to cut off the stock cats but flange both ends of the pipes, and then flange some offroad pipes so I can always go back to having cats for inspections or longer road trips.
Questions/comments/concerns? Lemme hear em!
CBRpilot is offline   Reply With Quote
Old 06-17-2013, 05:33 PM   #2
grocerygetter
instigator
grocerygetter's Avatar
JBA cat deletes. do it, don't look back. You can bolt back on your cats if need be.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 06-17-2013, 05:36 PM   #3
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
No such thing as no back pressure!
Unless you don't have headers lol
Remember you have an engine pumping 376 cubic inches.
Old 06-17-2013, 05:55 PM   #4
joeybsyc
joeybsyc's Avatar
Drives: 2010 Aqua Blue Metallic 2SS
This.
joeybsyc is offline   Reply With Quote
Old 06-17-2013, 06:23 PM   #5
Juiced1
Juiced1's Avatar
Drives: 2012 2SS CAMARO 45th
The JBA off road pipes do indeed sound perfect for what you're looking to do. They are an easy install and won't require any cutting so if you have to reinatall your cats down the road its another easy swap. It'll add some volume and some horsepower to your current set up.
GET MORE POWER PER DOLLAR!!!
We carry all the hottest brands for your Gen5 and Gen6 Camaros! Get awesome deals on Corsa, SLP, ARH, SW, Whipple, Kooks, Procharger, CAI, K&N, Rtoto-Fab and much more! Call us for your CAMARO5 discount today!
224-63-JUICE OR INFO@JUICEDMOTORSPORTS.COM
Juiced1 is offline   Reply With Quote
Old 06-17-2013, 10:47 PM   #6
CBRpilot
CBRpilot's Avatar
Drives: 2012 SS
Thanks guys! I've heard stock exhaust with this as the only mod and the sound is astronomically different. I'm slightly worried that I'll have a fair bit of drone but I'll address it later lol. Only problem is $220 seems a bit high for such a small piece of pipe. I'd imagine I could get my local guy to bend and weld up some flanges for around $150 installed. If not, these are mandrel bent and I'd prefer that so close to the headers.
Old 06-17-2013, 10:49 PM   #7
joeybsyc
joeybsyc's Avatar
Just buy them. They're nice mandrel bent pieces, and have the O2 bungs already in them, and fit perfectly with no cutting or hacking anything up.
