SDTW Custom Wheels & Tires
Old 06-18-2013, 09:57 PM   #1
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
GPI L99 Whipple w/ VVT Custom Grind *DYNO PG 2*
Results are in!
I installed a whipple with a 4" pulley, MSD Boost a pump, Zl1 pump, Custom Grind VVT, (already had LTs and CAI intake). Car drives good with stock converter, Idles at 700 rpm, and made great power despite the heat today!
611.7 rwhp and 527 rwtq on stock heads and stock bottom end, unlocked stock converter.
It made 6.8 lbs at 3000 rpm and at 6700 it was about 8.1 lbs.
Super flat tq curve and HP just climbs and climbs, and was still climbing at 6700 or so.
The cam works great in conjunction with the Brian Tooley springs. Valvetrain is super quiet and car makes great power everywhere.
The owner is a member here, I didn't get a pic of the graph before they left but Ill post it up when I get to the shop in the morning. Here is an idle clip though.
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
http://www.gwatneyperformance.com/
ryan@gogwatney.com jzajac@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
Old 06-18-2013, 10:00 PM   #2
Supercharged SS
Drives: 2010 Camaro
Are you going to install another cam for comparison?
Old 06-18-2013, 10:03 PM   #3
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
What cam do you have in mind? Compare it to which one?
Old 06-18-2013, 10:04 PM   #4
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Nice lope! Awesome numbers rhino!
Old 06-18-2013, 10:07 PM   #5
Supercharged SS
Drives: 2010 Camaro
A non vvt. No specific numbers in mind. That's your department. That shits Greek to me!!
I thought the plan was to show a blower vvt set up vs an ls3 conversion cam. Actually, someone prob already has a whip with an LS3 conversion cam.
Old 06-18-2013, 10:07 PM   #6
Rhino79
Rhino79's Avatar
Not on this one, Id like to do a comparison on one that already has a ls3 style cam. This car was on a deadline. I ran the cam at various spots during tuning, to determine where to set the cam timing at for each rpm point, and it made a nice difference in power from 5000 rpms and up vs leaving it at full advance (installed centerline).
Old 06-18-2013, 10:07 PM   #7
Supercharged SS
Drives: 2010 Camaro
TQ is low.
Old 06-18-2013, 10:08 PM   #8
Supercharged SS
Drives: 2010 Camaro
Understood.
Old 06-18-2013, 10:09 PM   #9
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Rhino when you get a chance post pics of the graph please.
Old 06-18-2013, 10:15 PM   #10
Rhino79
Rhino79's Avatar
TQ is low.
Cam is small, and at peak tq its only at 7 lbs with the 4" pulley. Also take into account I don't lock the converters on the dyno unless its a triple disk.
Old 06-18-2013, 10:17 PM   #11
Supercharged SS
Drives: 2010 Camaro
With the stock cam, on my TVS, I made 550 rwtq with 2 more psi? Is the extra boost worth that much?
Old 06-18-2013, 10:24 PM   #12
Rhino79
Rhino79's Avatar
About 20 hp per lb.
TVS cars typically have higher tq than the whipple, with the whipple being a 2.9 vs a 2.3 and only spinning enough for 7-8 lbs, its not as efficient as the Maggie at lower speeds. It needs another 2lbs on this car and we would see 560 tq easy and around 640 rwhp easy.
Old 06-18-2013, 10:26 PM   #13
Supercharged SS
Drives: 2010 Camaro
About 20 hp per lb.
Thanks Rhino.
Old 06-18-2013, 10:29 PM   #14
nyny69
nyny69's Avatar
Drives: 2010 IOM SS
Nice Job. I like
nyny69 is offline   Reply With Quote
