BeckyD @ James Martin Chevy
Old 06-18-2013, 11:23 PM   #1
Abrahams11SS
Drives: 2011 2SS Black-n-Orange
Stainless Works Retro chambered Catback issues
Initially my car was great.. No rattles and it went on pretty easily.. Not as easy as my friends Corsa or JBA exhausts but the sound made it well worth the extra work..
Since adding headers I started to get a rattle very rarely and now with a Cam it rattles daily... I have checked every connection and clamp and hanger and it's all tight and secure.. anyone else having issues ??
Abrahams11SS is offline   Reply With Quote
Old 06-18-2013, 11:37 PM   #2
Nutro
Nutro's Avatar
Drives: 2011 2SS Synergy Green
It's rubbing/vibrating on the tunnel brace
2011 L99 W/ Kooks Long Tubes, Ported TB, Roto-Fab CAI, MightyMouse can, Stainless Works 3" ZL-1 Catback, Overdriven Maggie @10 Pounds boost putting down 511/535 on a conservative tune.
Nutro is offline   Reply With Quote
Old 06-18-2013, 11:55 PM   #3
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
Could be tunnel brace, broken cat or broken muffler...If it's not the tunnel brace, take it to a muffler shop and have them take a mallet to it.
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 06-19-2013, 12:55 AM   #4
AutoAgenda
AutoAgenda's Avatar
Drives: 69 Camaro, 02 Escalade, 67 Eleanor
+1, there are a number of after market tunnel braces that offer more clearance so it doesn't rattle. This is a very common issue with 3'' exhaust, but a relatively easy fix
AutoAgenda is offline   Reply With Quote
Old 06-19-2013, 06:16 AM   #5
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
This is often the cause of rattles with 3 inch exhaust systems. I would start there.
Old 06-19-2013, 06:33 AM   #6
Abrahams11SS
With the spacers I must have a few inches of clearance. Even without them It clears with lots of wiggle room
Old 06-19-2013, 07:44 AM   #7
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
Try driving with the brace off and see if you still have the rattle.
FSP tuned: 377/389
Old 06-19-2013, 08:36 AM   #8
Abrahams11SS
This could genius. I will take it off this weekend and see if that solves the problem
Old 06-19-2013, 09:17 AM   #9
nyrfan
Let's go Rangers!
nyrfan's Avatar
FSP tuned: 377/389
Old 06-19-2013, 09:24 AM   #10
omgitsmikeyC
Drives: 2014 CTS-V Coupe
Anyone remove all of their heat shielding under the car to stop rattling? On WOT mine gets a metal on metal rattle, I have tried moving the shields and bending the corners away from the body. Only change to exhaust is axle-back, but the rattle is more central. I have removed the shields from the Stock manifold already.
2014 CTS-V... with some go-fast bits coming
omgitsmikeyC is offline   Reply With Quote
Old 06-19-2013, 09:29 AM   #11
nyrfan
Let's go Rangers!
nyrfan's Avatar
The HS shields are a bit of a pain once disdurbed and very flimsy. Took me some time to get them right again. There are there for a reason though and I would be very reluctant to remove them.
FSP tuned: 377/389
Old 06-19-2013, 10:55 AM   #12
Stainless Works
Stainless Works's Avatar
Drives: Fast
There are a lot of variables that could be rattling, Not just the exhaust. Not saying it is not the exhaust. If you could please take some pictures and send them to me i can make sure nothing looks really out of place to where it could be rattling. Also the rubber mallet is a good tool. Lightly tap each section and see if it rattles. Do this when it is cold and hot as the expanded metal may have moved to be touching something. If you have any questions feel free to contact me and i will be glad to help.
Quick question... Do you have a convertible?
Thanks, Chris
Chris@Stainlessworks.net
800-878-3635
Stainless Works is offline   Reply With Quote
Old 06-19-2013, 11:12 AM   #13
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
My 3" gets real close to the passenger side lower control arm and the diff. That is where all of my rattles have come from since I put the catback on. I eventually got everything tightened up in a way that made it happy.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 06-19-2013, 12:39 PM   #14
Abrahams11SS
ls3 coupe
