Old 07-01-2009, 09:02 AM   #1
Matt'sSS
From 2 door to 5 door
Matt'sSS's Avatar
Drives: C5 Vert->CGM SS RS M6->SRT8 Magnum
Can someone with factory bluetooth check something for us?
No tearing stuff apart, if someone could simply let us know if when you synced your phone with your car for both hands free and playing music via Bluetooth (A2DP), was it a single profile your phone had to sync to, or did you have 2?
In other words, when pairing your phone with your car, did you only have to do it once and everything worked? Or did your phone find 2 different profiles (one hands free, one music) you had to pair up to?
I'm guessing just one (as most other vehicles I've done it with) but wanted to be sure since it was in question.
Thank you!
Matt'sSS is offline   Reply With Quote
Old 07-01-2009, 09:32 AM   #2
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
I have a Black Berry Storm. When paired up with the blue tooth it will not play music via blue tooth from the phone. . . This option is just not available on any phone that I know of.
franknbeans is offline   Reply With Quote
Old 07-01-2009, 09:35 AM   #3
c0rsa180
c0rsa180's Avatar
Drives: 2010 Camaro SS/RS IOM
You have to sync your phone part and music part separately, So when you have your bluetooth music playing it will not allow your phone to work
Inferno Orange Metallic
2SS
RS
M6
ordered 2/17/09
c0rsa180 is offline   Reply With Quote
Old 07-01-2009, 09:43 AM   #4
Matt'sSS
Matt'sSS's Avatar
Thanks, that's what we were looking for! First time I've seen it work that way, but whatever works!
Old 07-01-2009, 10:44 AM   #5
mbauer14085RS/SS2010
mbauer14085RS/SS2010's Avatar
Drives: 99 blazer/2010 2ss/rs iom now
i paired it twice one for my phone and one for my music. i was still able to use my phone for texting while it was playing music. i have a samsung instinct
Ordered IOM 2SS/RS automatic with interior accent package and custom painted rally stripes.Order Detail # NJWH9M
1100 (4/30/09) 2000 (5/5/09) 3000 (5/5/09)
3100 (6/2/09) 3300 (6/2/09) 3400 (6/04/09)
3800 Order produced (6/16/09)2G1FK1EJ3A9117972
4000 Available to ship (6/16/09)
4200 Shipped (6/19/09)
4300 Intermediate Delivery(6/20/09)
5000 Delivered to the dealer(6/22/09)
6000 Delivered to the customer (6/27/09)
mbauer14085RS/SS2010 is offline   Reply With Quote
Old 07-01-2009, 06:39 PM   #6
BLUEMARO
A Classical Greek
BLUEMARO's Avatar
Drives: DTS, Bonneville and an SS !
two pairing profiles, one is gmusic connect and the other is general motors You can connect to both at the same time using the iphone
BLUEMARO is offline   Reply With Quote
Old 07-08-2009, 05:56 PM   #7
camarowa
camarowa's Avatar
Drives: 2013 SVT Raptor, sold 2010 Camaro
pair it twice. However, when using the GMusic I am no longer able to receive/make calls. In addition, I have to turn off GMusic on the phone and reconnect "General Motors" on the phone as well. It does not do this automatically. Verizon network, LG phone.
camarowa is offline   Reply With Quote
Old 07-08-2009, 06:02 PM   #8
Matt'sSS
Matt'sSS's Avatar
Anyone else have this problem?
Old 07-08-2009, 08:06 PM   #9
Aceman1120
Aceman1120's Avatar
Drives: Orange Metallic RS
I have an Iphone, paired twice...one for phone and one for Gmusic....it works AWESOME. I can even watch Movies, play Games, play Music Videos, YouTube, Youporn...He He...Like I said...It's Awesome!!!
Aceman1120 is offline   Reply With Quote
Old 07-08-2009, 08:17 PM   #10
nvrbacardi
Drives: Camaro 2010
Hi, I just bought a new Camaro 2010 and it comes with bluetooth. Im trying to connect my blackberry pearl for voice recognition but i just cant. When i enter to config/phone settings it just says not available. I also tried pressing the dial button but it just says no call list available. am I missing something ?
nvrbacardi is offline   Reply With Quote
Old 07-08-2009, 09:36 PM   #11
ckaram
ckaram's Avatar
Drives: 2011 2SS RS, 1968 ragtop
Did you go into bluetooth on your phone and search for devices? It should find GMconnect.
1968 Camaro convertible, LS1 & T56, Texas Speed 228R cam, 3.73 posi, 17" Torque Thrusts
2011 2SS/RS, LS3, M6, IOM in and out, factory Hurst short throw, GMPP axleback exhaust SOLD! Now in a 2016 Challenger Scat Pack Shaker, M6
ckaram is offline   Reply With Quote
Old 07-09-2009, 08:10 AM   #12
codeman71
GM Employee
codeman71's Avatar
Drives: 2006 Pontiac G6
The phone Bluetooth is not the one that I worked on, so I'm not exactly certain what would cause that message to be displayed. To clarify a few things, you will not be able to pair while the vehicle is moving, so if you were, that could cause that message.
If you go into Config and then Phone, you should be able to select pair. Don't select the GPS option because that's not gonna work. Once you select pair, a voice should come on with instructions on going into your phone and searching for General Motors. A 4-digit PIN will be read aloud to you and will be displayed on the screen. You'll have to enter that into your phone. Once you do that, it will ask you for a nametag. Give it something that will let you know what your phone is. You could call it Blackberry, or whatever you like.
Once you have that done, to get to the voice recognition on your phone, follow these steps:
1. Press voice rec button on steering wheel. System responds with 'Ready'
2. Say Bluetooth. System responds with 'Bluetooth Ready'
3. Say Voice. System responds with 'OK. Accessing [speaks nametag you recorded during pairing]
Then your phone will start listening and you can speak your commands like you would normally when using your Blackberry's voice recognition.
If you'd like a bit of a shortcut, you can store nametags for common people you call in the vehicle, so you just have to say Call, and then say the nametag that you recorded. There was a post on how to set this up, as well as the steps that I just posted above. Check it out here.
I work for GM and I designed the interface for the Camaro USB and Bluetooth audio streaming interface. Feel free to ask me any questions you have about how the USB or Bluetooth works!
Check out my videos on YouTube here. Let me know if you'd like to see any other type of video.
codeman71 is offline   Reply With Quote
Old 10-12-2009, 09:09 PM   #13
tjargote
Drives: Imperial Blue Mettallic 2LTRS
Great! Can you help with this? Why does my radio display "Unknown" next to the phone number of an incoming call that's stored on both my phone and the vehicle? I've gone through and stored my friends and family using the handsfree system in the car (and have them stored on my phone as well). Why doesn't the car caller ID? Have I missed a step during setup? Is it possible to access the phonebook via the radio? Just curious, this worked on an STS I had a while back. THANKS!!!
tjargote is offline   Reply With Quote
Old 10-13-2009, 12:41 PM   #14
oachalon
Drives: 2010 Camaro 1SS
People are correct with being two bluetooth units. One in the PDIM and the other in the VCIM (onstar). There are some people on the gm truck forums that purchased the VCIM with the bluetooth and the antenna and were able to add factory bluetooth to the truck. I dont know if this would work on the camaro or not, but i think just the VCIM out of the 2SS would work.
oachalon is offline   Reply With Quote
GROUP BUYS: F.A.S.T. LSXr intake and/or Long Tubes Group Buy..Check this out ! ZZcamaro V8 Bolt-Ons & Tunes 209 12-28-2009 05:19 PM
Factory Striping vs. Dealer Installed RetroDude Cosmetics and Lighting Modification Discussions 1 04-23-2009 02:01 AM
What is the number i can call to check the status of my order 95RedCamaroz28 Camaro Price | Ordering | Tracking | Dealers Discussions 3 03-23-2009 11:00 PM
LS7 Swap into V6 cheaper than factory? LSxcellent Off-topic Discussions 26 03-24-2007 12:20 PM
