BORLA
Old 06-19-2013, 05:38 PM   #1
msvwdude
Drives: 2011 1SS
Raising Ride Height and Alignment
I have pedders coilovers installed and am planning to raise the rear ride height from the current height of 646mm to 660mm. I'm not happy with the rear of the car sitting lower than the front. I realize that the rear end bushings should be re-timed and I should get it realigned but I can't get to the alignment shop for a few days. The question is can I drive the car for a few days and not be too worried about excessive wear on the tires and bushings, after all I'm only raising the back end 14mm?
Thanks
msvwdude is offline   Reply With Quote
Old 06-19-2013, 05:39 PM   #2
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
You will be just fine to roll around for a few days.
Best regards,
Tyler
888-308-6007
Old 06-19-2013, 05:47 PM   #3
jeremywes
jeremywes's Avatar
Drives: 2012 Camaro SS
Unless you plan to drive a thousand miles a day... ;-) you'll be fine
jeremywes is offline   Reply With Quote
Old 06-19-2013, 07:15 PM   #4
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
Running level ride heights help keep a 5th Gen composed and balanced.
The front wheel arch is taller than the rear wheel arch. That is why level ride heights can appear to have the rear lower than the front. When you raise the rear ride height negative camber is reduced and the toe moves in. You won't notice any additional wear in a few days of local driving.
Old 10-12-2013, 05:01 PM   #5
Cranky
Cranky's Avatar
Drives: 2012 Camaro V6 Manual 6 Speed
Have you jacked the rear up yet? If so do you have any pictures? I'm old school. Lets jack that rear end up.
Cranky...
Cranky is offline   Reply With Quote
