JUICEDMOTORSPORTS
Old 06-19-2013, 05:55 PM   #1
Nutro
Nutro's Avatar
Drives: 2011 2SS Synergy Green
Proper motor break-in?
Brand new motor. I don't have an owners manual handy, either.
2011 L99 W/ Kooks Long Tubes, Ported TB, Roto-Fab CAI, MightyMouse can, Stainless Works 3" ZL-1 Catback, Overdriven Maggie @10 Pounds boost putting down 511/535 on a conservative tune.
Nutro is offline   Reply With Quote
Old 06-19-2013, 06:21 PM   #2
62nalide
62nalide's Avatar
Drives: 2013 SS
700 to 1,000 miles try not to go higher than 4k rpms thats how i broke in 3 turbo motors and this 13 L99
10.45 @ 130mph all motor
GPI everythang!
Aka MR. NightFury Killer
62nalide is offline   Reply With Quote
Old 06-19-2013, 06:23 PM   #3
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
break it in like ur gonna drive it . if it wont hold at 5 miles it wont hold at 500. just check for shavings in the oil. if i race a car i break in running it hard.
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 06-19-2013, 06:37 PM   #4
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Have them fill it with joe Gibbs breakin oil!
After 30-50 miles of varying rpms never staying steady but not getting on it at all, change it.
Then after 100 miles of getting on it just a Lil more with proper heat cycles because they are needed for the bearings and springs change it.
Again at 500 and after 500 then it's all yours start beating that biach. At the 500 mile mark is use a good oil like how Gibbs 10-30 or amsoil signature or amsoil zrod or Valvoline vr1 10-30 synthetic.
That's just me I'm sure others have their methods.
Old 06-19-2013, 08:40 PM   #5
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
Joe Gibbs break in oil and onto the dyno. That's how I do it.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000, Built & Tuned by Seth at FEDERAL PERFORMANCE
realcanuk is offline   Reply With Quote
Old 06-19-2013, 08:46 PM   #6
fielderLS3
fielderLS3's Avatar
Drives: 2016 Mazda6, 2011 Mustang 5.0
The owners manual will say something like....for 1500 miles, no full throttle starts, no above 4000RPM and no above 100 mph.
If 100 people reply in this post, you will get about 50 different, conflicting answers.
"Proven V-8 power with better efficiency than a turbo V-6"
"The car is the closest thing we will ever create to something that is alive."eds.
fielderLS3 is offline   Reply With Quote
Old 06-19-2013, 08:49 PM   #7
james347
Drives: 2006 Crownline
Step 1: Get a couple of Go Pro HD Cameras.
Step 2: Mount one inside. One Outside.
Step 3: Run the ever living piss out of the car.
Step 4: Post videos on this website
james347 is offline   Reply With Quote
Old 06-19-2013, 08:55 PM   #8
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Old 06-19-2013, 08:56 PM   #9
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
Everyone is going to say something different.
For 1 Fu$k the manual break in. It's BS written by overzealous attorneys!
I'm more along the lines of Litle. I did pretty close as he has listed except once I hit 125 miles and took the conventional oil out I was frequently at WOT.
The 1st 500 miles are most important to get the rings seated properly, after that you're golden. My L99 runs like a beast and has 0 oil consumption.
My oil change intervals went like this:
Change to conventional with a high zinc content at 18 miles
125 back to Mobil 1
500 Changed again w/ M1
1500 Changed again w/M1
Now I change every 4K miles.
FSP tuned: 377/389
Old 06-20-2013, 07:12 PM   #10
Nutro
Nutro's Avatar
I don't know where to buy the Joe Gibbs locally. Is there another excellent oil to use that has a lot of Zinc and Phos?
Old 06-20-2013, 07:25 PM   #11
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
First 500 do not go over 4Krpm, then next 500 do not go over 5Krpm. Change oil to Pennzoil Platinum at 1K miles and have fun.
That's what I did.
Scott@Bjorn3D is offline   Reply With Quote
Old 06-20-2013, 07:31 PM   #12
firedrop
Drives: 2012 2ss/l99 a6, victory red
put the car up on a lift and leave a 50lb weight on the gas pedal all night
2012 2ss l99/a6
CAI, custom catback with flowmaster series 10s
firedrop is offline   Reply With Quote
Old 06-20-2013, 07:36 PM   #13
Mydivorcegift
GPI Built
Mydivorcegift's Avatar
Drives: 2011, 2SS/RS, Synergy
I buy it from Summit..When they have it on sale, with free shipping, and I put summit bucks with it..
GPI Built 416.
513rwhp/488rwtq
Track times coming to back it up.
Mydivorcegift is offline   Reply With Quote
Old 06-20-2013, 07:36 PM   #14
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Valvoline vr1 bud. A conventional 10-30
