Old 06-19-2013, 07:13 PM   #1
Michaels2011
Michaels2011's Avatar
Drives: 2014 2lt/RS
Pass side turn signal...
Got a dash note to check passenger turn signal bulb. The right turn signal was clicking fast when it was engaged. Changed the bulb, now nothing works.
Ideas/suggestions...
K&N cai..... WCC underhood lighting.... 1LE strut tower brace.... Custom painted Fuse box/engine covers & strut tower brace.... Pfadt 1.25 lowering springs.....Ghosted side markers.....
Michaels2011 is offline   Reply With Quote
Old 06-19-2013, 08:08 PM   #2
zkdreads
zkdreads's Avatar
Drives: 2010 Camaro LS V6
check wires. move around to make sure nothing is loose or cut or anything. maybe a bad ground. make sure plugged in securely
C-LO or Sonic
"Without Struggle there is no progress"
I am your best nightmare!
zkdreads is offline   Reply With Quote
Old 06-20-2013, 02:18 AM   #3
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
I recently had this happen the turn signal warning only says Check Passenger/Driver Turn Signal it's not the front signal if it's on and clicking fast it means one of your turn signals period is out on that side of the car. I had the exact same message checked my front it was clicking fast same as my sidemarker and rear lights it ended up being the inner passenger tail light was out. Aside from that being a solution check your connections like ZK said.
MY 2017 I4 CAMARO BUILD JOURNAL | YOUTUBE | INSTAGRAM | 307RWHP - 329 RWTQ HPTUNERS DYNO TUNE
Evil-Bee-NH is offline   Reply With Quote
