sjm autoprod
Old 06-19-2013, 06:41 PM   #1
Learjetguru
Learjetguru's Avatar
Drives: 2011 2SS LS3
Lunati 21460701
I got this from Lunati
The cam I recommend is part number 21460701. This cam is on the single
bolt core and it is 217/228 at .050, .549/.566 on the lift, and it is cut
on a 112 LSA with a 108 intake centerline.
If any one has any experience with this grind cam. I am all ears. Thanks
2011 Camaro 2SS
1969 Camaro BB 472 NOS
1997 Camaro Z28
Learjetguru is offline   Reply With Quote
Old 06-19-2013, 06:59 PM   #2
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
You will get responces about it being a single bolt as compared to a 3 bolt. Not enough split on the duration and not enough lift. I feel it will make decent power and be easy on the valve train.
Bo White is online now   Reply With Quote
Old 06-19-2013, 07:18 PM   #3
Learjetguru
I am expecting that. It's not my first rodeo. I do appreciate the comment on the front end. Maybe it will cut down on just what you are talking about. Thanks:
I would love to hear from someone that has installed this grind cam and dyno
2011 Camaro 2SS
1997 Camaro Z28
Old 06-20-2013, 09:44 AM   #4
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
You can use the stock valve train which is a plus.
the overlap is -1.5°, so don't expect much of a choppy idle... Stock is -11°. Bigger choppy cams are > +10°.
... and opt for the 3 bolt design. I can post a link that will convince you if needed.
I expect that the closest you will find to this cam is this one: http://www.camaro5.com/forums/showthread.php?t=301081
EDIT: It looks like -1.5° sounds pretty awesome judging from the next post. I didn't realize that it was the exact same cam.
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
Old 06-20-2013, 11:34 AM   #5
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
This is that cam, posted this many times. Yes it chopes good, makes great power! Car traps 115-116 in 2000ft DA, once I get the little stuff worked out I would bet I see 120 traps in good weather. I mad about 450hp and 430tq at the wheels, peaks at 6400. And yes I use the single bolt cam, and full stock valav train with about 12k miles since the swap.
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 06-20-2013, 11:39 AM   #6
Kelly@PCMofNC
Drives: 2010 RS/SS
Not bad, but better things out there. In my opinion if I am going to take the time to install a cam, I don't want to compromise. Our '545' cam has been selling like crazy lately, and it usually makes 470-480 to the rear wheels on a dyno jet with bolt ons. It's insanely torquey and retains great driveability as well...and you can't beat the lope!
Kelly - sales@pcmofnc.com - 704-307-4227 www.pcmofnc.com
Kelly@PCMofNC is offline   Reply With Quote
Old 06-20-2013, 11:58 AM   #7
Bo White
Bo White's Avatar
Does the 545 cam work with stock springs though. Believe that's what the op is after.
Old 06-20-2013, 12:15 PM   #8
Bad70supreme
No pretty sure it don't! Yes there better cams out there, but they also cost a hell of allot more money to install. It's took a measly 6hrs from start to finish to install and have what I have. Spent less then 800$ between the cam and the tune and my car runs very strong. All depends on your budget and needs, I have beaten and ran neck and neck with the so called better cams, so I am happy.
Old 06-20-2013, 12:45 PM   #9
2012-2SS
2012-2SS's Avatar
Drives: 2012 Camaro 2SS/RS
Been looking into this exact cam
Sounds awesome! And all on the stock valvetrain? Even better! Now that's something I can install myself.
How's the low end on it?
2012 Camaro 2SS/RS, Hurst Short Throw, IdealG M/C, Pypes Pipe Bomb, LSR Cold Air Intake, LSR Toe Links/Lower Control Arms Clear Image headers, high flows, Slowhawk tune
1974 Chevy K10 Built 355, FAST EZ EFI, 5speed
2000 Chevy Tahoe LT 5.3L, Slowhawk tune
2012-2SS is offline   Reply With Quote
Old 06-20-2013, 01:34 PM   #10
Bad70supreme
Thanks, this cam makes a very flat power band. There is no top end rush after a laggy low end feel, just a nice strong pull right off the bat. I really have no plans to swap to a larger cam until I do my 416/427... I am totally happy with it in my application, and positive it will put my car in the 11s. For a street toy that see some track use, it is a very Big Bang for the buck!
Old 06-20-2013, 04:26 PM   #11
caverman
caverman's Avatar
Drives: '69 SS Convertible
Sounds good to me....and being able to use the stock springs is a big plus to me. This might be something I will have to look at installing some day.
About how much is the cam? I'm also guessing you used the stock oil pump as well?
Build Journal
Old 06-21-2013, 08:38 AM   #12
Bad70supreme
Yes I reused everything, I had 34k on my car when I swapped it. I now have 47k, I drive mine pretty much daily and I like the fact I don't have to worry about valve springs with the crazy high lift most of these cams run. The car sounds great, and I can walk a Bolton car like nothing, so even though it don't make big numbers it does perform. You can pick this cam up for under $400, reuse everything an get a tune... All done! It really is a great street car cam, this is the 4th cam I have used from lunati, they never disappoint. This cam was specificly made for the ls3, so that is what sold me on it. Also my avg trap speed picked up from 110 to 115 in some pretty high DA. My best Bolton traps were 112, and now 116s and I still haven't seen great air with the cam!
Old 06-21-2013, 09:13 AM   #13
caverman
caverman's Avatar
This is the kind of cam I'll be looking for when I'm ready. Part of what's been holding me off from a cam swap is dealing with all the springs and stuff. Also know that you're supposed to switch out springs every 25k or so has just turned me away.
Even though that cam isn't the most choppy one out there, you can definitely hear it and I'm sure it has a lot better street manners than those bigger lift cams.
Build Journal
Old 06-21-2013, 09:25 AM   #14
Bo White
Bo White's Avatar
If you have to run comp cams you have them cut a 218/228-.562/.571
