SDTW Custom Wheels & Tires
Old 06-19-2013, 09:05 PM   #1
Craig B
Craig B's Avatar
Drives: 2013 1LE
Help SLP under-drive pulley
Need some help with belt part #. The SLP instructions say to use a serpentine belt that's 82.7 long. Looks way to long for the 2013, now the instructions only list 2010 model. Also how do I find a 2013 belt diagram [ think GM would of put that under the hood? They forgot that with the AC belt tensioner.
Craig B is offline   Reply With Quote
Old 06-19-2013, 10:09 PM   #2
SSMickey
SECC
SSMickey's Avatar
Drives: 2010 IBM 2SS
Can't help you with the belt length, but there should be a belt routing diagram in the owners manual, technical data section. At least there is in the 10 & 12 manuals. For what it's worth, I learned a long time ago that my memory is garbage, so I make a quick sketch before I remove any serpentine belt.
Vengeance Stage II Cam, Halltech CAI, RX Catch Can, Full ARH Exhaust, QTP Cutouts, Powerbond 25% Underdrive, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 06-19-2013, 10:10 PM   #3
BLACK10
BLACK10's Avatar
Do you have electronic steering?
Edit, i see you have a 1LE. You have electronic steering. This is why you have a shorter belt
Old 06-19-2013, 10:14 PM   #4
Craig B
Craig B's Avatar
Drives: 2013 1LE
Yes I do have electronic steering.
Old 06-19-2013, 10:17 PM   #5
BLACK10
BLACK10's Avatar
Your accessory drive belt is the same as a ZL1
You will probably have to measure your belt length and get it from a local parts store since you have put the underdrive pulley on it.
Old 06-19-2013, 10:31 PM   #6
IMJ
IMJ's Avatar
Drives: 2012 SS LS3 | Silver Frost Metallic
Wondering why no one sells this pulley as a kit with a gator back belt? Also, while we are talking pulleys, does anyone know how many of the different pulleys can be replaced on this car?
Are these lighter and hence less rotating mass, or are these smaller pulleys? I'm just turning my attention to these now...
__________________________________________
Ironman John
IMJ is offline   Reply With Quote
Old 06-19-2013, 10:36 PM   #7
BLACK10
BLACK10's Avatar
The gates green stripe is a better belt imo. The electric steering is pretty new so no one has probably put it together in a kit yet.
We just recently installed an Underdrive pulley on a Dusk edition and just got the belt our selves. Ill try to find the belt size we used.
Btw, the ac belt has a tool that is used to install it. It usually comes in the box with the new belt from GM.
Old 06-19-2013, 10:40 PM   #8
Craig B
Craig B's Avatar
Drives: 2013 1LE
Btw, the ac belt has a tool that is used to install it. It usually comes in the bix with the new belt from GM.
If you could find out the belt size that would be great. Thanks for your help.
Old 06-19-2013, 10:52 PM   #9
BLACK10
BLACK10's Avatar
Here you go. This should work with most electric power steering models with a Ud pulley. Do keep in mind that this is with a Katech tensioner. You may need a 1" longer belt with the stock tensioner but this will give you a good place to start
K060750
Old 06-19-2013, 11:00 PM   #10
trw427ss @ Futral
trw427ss @ Futral's Avatar
Drives: 2013 2SS/RS L99
If it is a 25% under drive the AC belt #4K350 and the main drive belt #785K6. This is what I have on mine.
2013 2SS/RS L99/A6 Crystal Red Metallic Tincoat 12.76@108.98mph Bone Stock
12.46@111.19mph with New Era CAI & U/D Pulley
12.12 @ 114.16 after Stainless Power headers and no tune yet on stock P-Zero's!
12.007@ 115.20 With 18" Drag Radials - 11.93 @115.19 Added a PTB 11.76 @116.59 With Yank SS3200 Converter - 11.63 @116.52 After PI and Tuning 11.44 @118.75 New Best
10.72 @127.93 after heads and Cam and Yank SS3600
trw427ss @ Futral is offline   Reply With Quote
Old 06-20-2013, 12:24 AM   #11
62nalide
62nalide's Avatar
Drives: 2013 SS
Thanks ^^^^^^^^^
62nalide is offline   Reply With Quote
Old 06-20-2013, 05:29 AM   #12
Craig B
Craig B's Avatar
Drives: 2013 1LE
K060750
Thanks for the info. I will head out to the parts store today. Trying to wrap this up before my headers show up.
Old 06-20-2013, 05:30 AM   #13
Craig B
Craig B's Avatar
Drives: 2013 1LE
Do you have electric steering??
Old 06-20-2013, 10:01 AM   #14
trw427ss @ Futral
Yes, standard on the 13 SS.
