sjm autoprod
Old 06-20-2013, 07:07 AM   #1
CAP'N B
Cajun Mariner
CAP'N B's Avatar
Drives: 10 Camaro SS/RS 15 Camaro Z/82 AGM
Send a message via Yahoo to CAP'N B
Road course this weekend
I'm running my car this weekend on the road course at NOLA Motorsports this weekend. I have the X/A coilovers, any Ideas on a good place to start on the settings.
'10 Camaro 2SS/RS Red Jewel L99/A6
'15Camaro Z/28 Ashen Gray
CAP'N B is offline   Reply With Quote
Old 06-20-2013, 08:43 AM   #2
Iron Lung Jimmy
Drives: Iron Lung, Jimmy
I'm told the track is really smooth so don't be afraid to stiffen them up. I can't help you with exact numbers or personal experience but based on advice I was given I'd probably start at 25ish and see how that goes.
I hope to get out there soon myself.
Iron Lung Jimmy is offline   Reply With Quote
Old 06-20-2013, 09:56 AM   #3
SPCBA
Drives: pleather and Chiclets
what tires and alignment are you running?
SPCBA is offline   Reply With Quote
Old 06-20-2013, 10:16 AM   #4
CAP'N B
Cajun Mariner
CAP'N B's Avatar
The tires are, General GMax in the stock size, I think the alignment is aggressive. The sways are full stiff on the back, and one hole on passenger side from full soft on the front.
Old 06-20-2013, 10:30 AM   #5
jeremywes
jeremywes's Avatar
Drives: 2012 Camaro SS
Depends on tires, corner balance, air pressure, track design, surface quality, etc. but somewhere around 20 or 25 should be a good start. Some front bias will need to be adjusted but that is very dependant on your specific car. some tire chalk and a heat probe are also useful in getting your settings dialed in.
jeremywes is offline   Reply With Quote
Old 06-20-2013, 01:26 PM   #6
Iron Lung Jimmy
CAP'N B... please post whatever settings you end up using and how it goes.
Hopefully it doesn't rain.
Old 06-20-2013, 03:48 PM   #7
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
set the fronts to 16 from full soft or hard. You'll end up in the same place. In the rear count down 12 from full hard. If you feel more push than you like, make the rears a couple of clicks harder.
Start your tire pressures at 32 cold. You don't want to run more that 40 or 42 hot. After the first session while hot, check the pressures and bleed down to 40. If under 40 add air and you'll be very close. to the target pressures at the end of your next session.
Be Safe. Be Fast.
Old 06-20-2013, 07:05 PM   #8
CAP'N B
Cajun Mariner
CAP'N B's Avatar
Tire pressures are at 34 now and I will drive the car there(about an hour and fifteen mins.) so I will get them hot and will be able to adjust them then.
Old 06-20-2013, 07:10 PM   #9
ddunerider
So-Cal Race team!!
ddunerider's Avatar
Drives: Tahoe LTZ,2010 2SS/M6 Camaro
Send a message via AIM to ddunerider
On a road course out here I ran 17 from full soft on rear and 19 up front...
WE RACE DEEP!!
BBK Intake, Flowmaster AT cat back Barton shifter,Painted stripes,,Heritage grill,LED DRLs, Smokin Tires!!
ddunerider is offline   Reply With Quote
Old 06-20-2013, 11:28 PM   #10
CAP'N B
Cajun Mariner
CAP'N B's Avatar
The tires are what's gonna decide what I can run on, until I can get better wheels and tires.
Old 06-21-2013, 11:00 AM   #11
SPCBA
Yup. Not gonna lie you have really bad tires for a road course...the tires wont be happy if you push it. Which is a good thing because you will find the cars limit (because of the tires) and learn how to drive withen said limits.
Old 06-24-2013, 01:03 PM   #12
CAP'N B
Cajun Mariner
CAP'N B's Avatar
The tires were the weak link, like I thought, at 34 lbs cold they ended up at the end of the run at 40, I had the rear coilovers at 18 and the fronts at 16, the instructor was impressed with the handling of the car. Not so much with the driver. LOL, JK he recommended that I was ready for solo driving. I had a great time, the car carry's a lot of speed and takes time to slow it down, coming out of turn 16 down the front stretch I topped out at 128mph in 4th gear(my car is an A6). I started braking around the 300' mark.
Old 06-24-2013, 02:03 PM   #13
SPCBA
nice! glad you had fun
Old 06-24-2013, 02:09 PM   #14
JusticePete
Shopping List
Pedders Custom. Brake Pads
Forgeline 19x11 Wheels
Bridgestone RE 11 305/30/19/XL
More Pedders :-)
