Old 06-20-2013, 02:11 PM   #1
Enegem
Drives: 2011 Camaro
3.27 vs 3.73
Ok , CAI in , Borla Exhaust in - Now I have to convince the wife I need gears .
Have the stock 3.27 in , Looking to upgrade to 3.73 .... I'm pretty sure I will see an improvement at 1st , 2nd and 3rd , But dont believe I will see much difference pass thet - Anyone do the chage over yet ? Results ?
Also , I need a creative way to explain to the wife exactly why I need them . Any Suggestions ?
lol
Al
Enegem is offline   Reply With Quote
Old 06-20-2013, 06:11 PM   #2
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2012 2LT RS
V6 or v8? Stick or auto?
2012: e85, 80mm TBody, CAI w/scoop, Solo HFC, ZL1 FP, Magnaflow TruX, Dynomax VT, Elite catch can, HP Tune, Throttle Contoller, BMR; Springs, Sways, Trailing Arms, Toe Ends, & Safety Loop, Koni str.t, Pioneer Z150bh, Phoenix Gold Sub, Hertz speakers & 5ch Amp, 1LE rear with 3.91 gears, BMR bushings, Baer Decela Rotors, Goodridge brake lines, Brembo(GM) 4 piston calipers, Hawk Ceramic pads, ported intake, Circle D 5c. 12.3@112 old setup
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
IneedAZ is offline   Reply With Quote
Old 06-20-2013, 06:14 PM   #3
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2010 2SS/RS/M6
You will feel a difference in every gear.
dont tell your wife anything...just get them.
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 06-20-2013, 06:40 PM   #4
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
lol
Al
Gear changes will be felt in all gears at all RPM. Upgrade the factory 3.27s to 3.73s and you will realize an equivalent torque gain of approximately 15% EVERYWHERE. If you have a V6 that is like an extra 41 lb.-ft. of torque across the board. If you have an SS it is like an extra 62 lb.-ft. of torque.
Old 06-20-2013, 09:36 PM   #5
Enegem
Drives: 2011 Camaro
V6 , Auto .....
Old 06-20-2013, 10:01 PM   #6
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
V6 , Auto .....
One might want to put that in his signature or the "drives" section that shows up at the left every time you post.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 06-21-2013, 07:19 AM   #7
IneedAZ
IneedAZ's Avatar
V6 , Auto .....
OK, you are in the same boat as me. I have a V6 Auto. In order to go to 3.73 you will have to change out the rear from an SS as only 3.55 gears are made for the Auto. The Manual V6 uses the same rear as the SS already. I went ahead and made the swap as it gives you heavy duty axles and rear compared to the smaller V6 auto. Also you will gain a limited slip as the AutoV6 doesnt have one. I went with 3.73 in mine. Unfortunately i cannot say the difference in the 1/4mile as i didnt take it to the track prior. You will find it runs better when in sport mode, but in normal D mode i find 1st gear shift really quick.
Old 06-21-2013, 07:20 AM   #8
IneedAZ
IneedAZ's Avatar
What part of Florida are you?
Old 06-21-2013, 08:26 PM   #9
Enegem
Drives: 2011 Camaro
Melbourne ....
Old 06-21-2013, 08:28 PM   #10
Enegem
Drives: 2011 Camaro
Yeah , Thats the census .... Researching still .
Old 06-23-2013, 11:24 AM   #11
Vader2011v6
Vader2011v6's Avatar
Drives: 2014 custom blue ZL1
Does anyone have any suggestions on where to buy a good set of 3.73 gears and pricing? Thinking about doing this mod in the near future I have an M6 V6
Custom blue 2014 ZL1. Cold air intake,clear bra,apex springs,apex oil catchcan,18 percent pulley,stainless works long tubes wit high flow cats,ls3 throttle body, (595tq/607hp) to the wheels
Vader2011v6 is offline   Reply With Quote
Old 06-23-2013, 04:33 PM   #12
camarostar2010
Drives: 2011 SS
wow...nice number increases. I would personally go 4.11 gears
camarostar2010 is offline   Reply With Quote
Old 06-26-2013, 10:43 PM   #13
tanur420
Drives: 2011 Camaro SS
do you have to recalibrate speedometer with gears or just plug and play?
tanur420 is offline   Reply With Quote
Old 06-27-2013, 07:11 AM   #14
IneedAZ
IneedAZ's Avatar
You will need a tune to recalibrate the speedometer. I found mine to be off by ~10mph going to the 3.73. After the recalibration i am within 1mph. Close enough for me. I had my gears installed in Bradenton area. They supplied everything. They can do it while you wait, took about 4 hours. If interested pm me for their number.
