Old 06-20-2013, 05:29 PM   #1
Nick S
Nick S's Avatar
Drives: 2013 Camaro 1LE
M6 Transmission Drain & Fill Plug Sealant?
For those of you that have changed your manual transmission fluid did any of you use any new sealant on the drain and fill plugs?
I recently received my 2013 Camaro Service manual set and it doesn't say to use any new sealant on the plugs it only lists a torque spec.
But in another section of the manual they do list the GM part number for the drain and fill plug sealant.
So I was just wondering if any of you have bothered to apply any new sealant to your fill and drain plugs when servicing your trans fluid.
Thanks in advance for any help.
Nick.
Nick S is offline   Reply With Quote
Old 06-20-2013, 06:21 PM   #2
Mouse6.2
Mouse6.2's Avatar
Drives: 2013 2SS/RS M6 NPP
I didn't and no leaks.
Mouse6.2 is offline   Reply With Quote
Old 06-20-2013, 11:14 PM   #3
crazy4camaro
Drives: 2012 RSLT,1979 Trans Am
no leaks and no problems .........
crazy4camaro is offline   Reply With Quote
Old 06-20-2013, 11:19 PM   #4
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
There may be a crush washer you could replace, but I don't think I would want sealer potentially getting into my transmission.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 06-21-2013, 07:08 AM   #5
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
Did not apply sealant. No issues.
N.O. Plate(dedicated fuel tank, progressive, fuel hose upgrade, remote opener, heater, console switches), LNC2000, ARH 1 7/8" LTs/gutted cats/X pipe/mufflers, Jet Hot coated LTs, JRE SCT Tune, CAI, Scoop, Rx Catch Can, Gates heater hose relocation, Remote clutch & auto brake res, Metco loop, Momentum Tunnel Brace, TSW Nurb 18" 555 & 555R, Pfadt trailing arms & toe rods, Autometer wideband, Fesler Pillar Pod, LED strips (int), Lloyds floor & trunk mats, LED DRL/front turn & license plate, DRL harness, VLEDs tail lights, Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 06-21-2013, 07:26 AM   #6
Nick S
Nick S's Avatar
John B.
The drain and fill plugs are more of a NPT plug type. There is no bolt head or shoulder to bottom out against. It's just a fully threaded plug with a sealant that looks similar to pipe thread sealant you would use on pipe fittings and such.
Old 06-21-2013, 07:27 AM   #7
Nick S
Nick S's Avatar
Thanks for the info guys.
I recently changed the trans fluid on my 2002 Camaro and the plugs are the same style and I did not use any new sealant there either. I also have not had any leaks yet but I haven't really driven the car very many miles since then so I didn't want to rely on my very limited mileage experience.
Old 06-21-2013, 12:49 PM   #8
Synner
Drives: not stock
You can buy thread sealant at any parts store. There's zero risk of it getting in the trans unless you use way too much.
Old 03-31-2015, 08:12 PM   #9
Tennis_pro
Drives: 2012 ZL1
Bringing back an older thread. I changed the manual transmission fluid in my 2012 ZL1 today and I know what you are talking about. It's the read sealant on the threads of both the fill and drain bolt. I thought at first someone who had the car before me changed the fluid and put that on there themselves. I tried scrapping a little of it off but couldn't really get it so then I looked up the part and saw that these bolts come that way. So I just put them back on and torqued them down. Seems with the sealant on them they will torque down quicker without having to screw in as far. In the end I torqued them down and I don't think there should be a problem.
Tennis_pro is offline   Reply With Quote
