Gen5DIY
Old 06-20-2013, 09:13 PM   #1
rray
rray's Avatar
Drives: 2013 GAZ 2SS/RS
TIP: How to turn on DLR's Daylight Running Lamps to test operation:
I replaced the incandescent DRL's on my new 2SS/RS with 5000K LED assemblies from ebay, which have a polarity key, that matches the bulb socket so you cannot install them wrong.
Then I refered to the conditions outlined in the owners manual page 6-2, and the DRL's would not light up.
Owners Manual says:
Ignition in On/Run.
Lamp control knob in Auto.
Engine is Running.
No Dice for Automatic Transmission!
What DOES turn on the DRL's:
Engine Running.
Parking Brake ON.
Shift to Neutral.
The Owners Manual may have been written with the manual transmission in mind.
Cost me an hour of searching the web for answers, so I hope this post will help someone else get through it faster.
-Robert
rray is offline   Reply With Quote
Old 06-21-2013, 11:23 AM   #2
Zikma
Zikma's Avatar
Drives: ZL1 2012 # 721; 2013 Tahoe Z71
For the Manual Transmission the DRLs come on when the E brake is released.
Zikma is offline   Reply With Quote
Old 06-21-2013, 06:35 PM   #3
rray
rray's Avatar
Same with the Automatic, however if you are by yourself, and you get out of the car to see if the lights are on...
My car started rolling when in neutral, so I added that one for safety.
Old 06-22-2013, 09:01 PM   #4
Buckeye
Buckeye
Drives: 2013 2SS RS 1LE
I installed a set in a member's automatic car and they did not turn on until the tranny was put in drive. This was on a 2010 2SSRS.
Buckeye is offline   Reply With Quote
Old 06-22-2013, 09:45 PM   #5
Glen e
Glen e's Avatar
Drives: Garnet 2LT RS
correct....in rewiring mine, it was clear that they came on when you were ready to drive, meaning "D"....
Glen e is offline   Reply With Quote
Old 06-22-2013, 09:53 PM   #6
Angrybird 12
6 year Cancer Survivor!
Angrybird 12's Avatar
Drives: 12 CAMARO, 13 Encore, 07 Colorado
I can usually see mine when pull up behind a car or truck with a shiney back end and look at the reflection of my car. Usually at a stop light.
Cancer's a bitch! Enjoy life while you can! LIVE, LOVE, DRIVE...CAMARO!
The Bird is the word!
camaro drl's, daylight running lamps, test camaro drl's
