Old 06-20-2013, 10:46 PM   #1
Tweiten
Tweety
Tweiten's Avatar
Drives: 2010 Camaro 1LT RS
Bad Paint Job on Engine Cover
Wish I could upload pictures but I can't go outside right now and get a picture do to a storm. Anyways, I just need to remove the paint from my engine cover. It turned out terribly and I want to redo it. Also, can someone give me a link to the right type of spray paint for the engine cover? I need a red kind.
Tweiten is offline   Reply With Quote
Old 06-20-2013, 11:13 PM   #2
Bonanza7
Drives: 2010, Rally Yellow, Black stripes
I don't think it really matters. I use Duplicolor on one, and Krylon on another. No problems in 2 years. Prep is the big thing.
Bonanza7 is offline   Reply With Quote
Old 06-20-2013, 11:14 PM   #3
greenbadass
Drives: 2011 2SS Synergy Green Camaro
Try this site. http://www.automotivetouchup.com/
I have a Synergy Green Camaro and they matched the paint code perfectly. You need to find out your paint code. It is located under your trunk liner. Its the last numbers on the sticker.
greenbadass is offline   Reply With Quote
Old 06-20-2013, 11:15 PM   #4
greenbadass
http://www.automotivetouchup.com/tou...t/2010/camaro/
This is the direct link to your rally yellow.
Old 06-20-2013, 11:21 PM   #5
Blue17CamaroZL1
650HP soon to come
Blue17CamaroZL1's Avatar
Drives: 2017 Chevy Camaro ZL1
I used http://www.expresspaint.com/
The way I painted it:
1) clean all to be painted surfaces
2) use expresspaint.com Prep-All spray
3) sand down to be painted surfaces
4) light coat prime all to be painted surfaces with Primer
5) wait 10 minutes then second coat of primer
6) wait 15 minutes then light coat of paint, and you wanted Red Jewel paint
7) wait 10 minutes then second coat of paint.
8) wait an hour
As long as everything is the way you want it, then
9) light coat of Clear Coat
10) wait 10 minutes then second coat of clear
11) wait 24 hours to fully cure
Results for me using Imperial Blue Metallic and Summit White:
same paint on fuse box:
2017 Camaro ZL1
Hyper Blue Metallic
A10, PDR, NAV, Premium floor mats
Blue17CamaroZL1 is online now   Reply With Quote
Old 06-20-2013, 11:27 PM   #6
montreal2010yellow
montreal2010yellow's Avatar
To take out the bad paint. When I did some plastic car modelings I used BRAKE FLUIDS to take the paint off. Just summerge the cover in a bassin fiilled with brake fluid and let it overnight. It does work for plastic model cars, can't see why it would'nt work on the engine plastic.
Old 06-21-2013, 06:33 PM   #7
Tweiten
Tweety
Tweiten's Avatar
I have Victory Red
Old 06-21-2013, 07:12 PM   #8
Glen e
Glen e's Avatar
Drives: Garnet 2LT RS
I used these with good result. pic below is before the last two coats of clear.
Glen e is online now   Reply With Quote
Old 06-22-2013, 01:26 AM   #9
Tweiten
Tweety
Tweiten's Avatar
Originally Posted by Baugher17 View Post
http://www.ebay.com/itm/2010-2013-Ca...8&cmd=ViewItem
Hello, above I posted the link for you guys to check out my amazing V8 engine cover and fuse box cover set I have on Ebay! Simply copy and paste it into the address bar. I hope you all don't mind me posting it but I think you all will be very impressed and be able to appreciate the time, effort, and quality we have in this product. Thanks for your time and please let me know what you all think of it. Thanks!
Thanks but I don't have a V8 or $400+ plus to spend on it.
Old 06-22-2013, 01:27 AM   #10
Tweiten
Tweety
Tweiten's Avatar
That looks great. Where'd you get the VHT paint?
Old 06-22-2013, 01:30 AM   #11
Tweiten
Tweety
Tweiten's Avatar
Think I could use this to take off the paint?
http://www.amazon.com/Gunk-M4432-Reg...ds=brake+fluid
Old 06-22-2013, 01:45 PM   #12
Glen e
Glen e's Avatar
any auto parts store
Old 06-22-2013, 11:03 PM   #13
KEEP RT
Wonderfully Awful Idea
KEEP RT's Avatar
Drives: 2010 2SS/RS
Break fluid is NOT the way to go!
Reducer is what you need. All auto paint stores have it as wall as parts stores.
KEEP RT is offline   Reply With Quote
Old 06-23-2013, 12:36 AM   #14
Tweiten
Tweety
Tweiten's Avatar
What is that? Like do you have a picture or a link or something. Never heard of that?
