R1 Concepts
Old 07-01-2009, 12:53 PM   #1
Camar0wn3d
formerly "wh0rsep0wer"
Camar0wn3d's Avatar
Drives: 2010 1SS RS CGM
Rear View Mirror Rattling After Sub Install- UPDATED W/ DIAGNOSIS
****UPDATE****
After messing with it a little more I found out the rattle is coming from the little plastic tab on the bottom of the mirror that moves it to the "dim" position (1SS - don't have the auto-dimming mirror.) I'm going to put some adhesive felt on that tab when I get home and should take care of it!
Just wanted to give an update in case someone else has a mirror rattle they can't figure out.
So I just installed my subwoofer last night (JL 10W3V2 being pushed by an MTX 421D - 300W RMS) - and even at low volumes I get a terrible rattle from my rear-view mirror. .Never had it before the sub because I guess the stock (non BA) system didn't produce low enough frequencies to make it rattle.
Anyone else with a sub have this problem? Anyone know a good fix for it?
Everything I've read suggests opening up the mirror and putting dynamat or some kind of foam in the mirror housing...and I'm not really cool with that. Would this be considered warranty worthy? (I mean...the rattle is really loud).
2010 1SS/RS - CGM/Gray Interior - M6
SOLD (stupid recession)
Kooks 1 7/8" headers, Solo Mach-X, Vararam.
2012 2LS - I'm back in BLACK!
Camar0wn3d is offline   Reply With Quote
Old 07-01-2009, 01:05 PM   #2
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
Wouldn't think it's covered under warranty, unless it was loose to begin with. And if you're looking to rattle loose your interior roof linings while bouncing quarters off the roof, that wouldn't be covered, either..
Old 07-01-2009, 01:10 PM   #3
Camar0wn3d
Camar0wn3d's Avatar
I know. I'll put wheel weights on the mirror and fix the problem Brembo-style.
Old 07-01-2009, 02:39 PM   #4
AhX
AhX's Avatar
Drives: 2010 2SS IOM\IOM
seems normal to me. Never had a car that DIDN'T Rattle with a sub.
AhX is offline   Reply With Quote
Old 07-01-2009, 06:23 PM   #5
Chief Mario
Chief Mario's Avatar
Drives: 2017 2SS 50th on order..
That is to be expected, however it should only happen at high volume. If you are seeing the rattle at low volume, check for deficiencies in the mirror and its installation, i.e. anything loose. I have a 10" clarion sub in my SUV and my rear mirror dances to the low frequencies everytime I crank it up, btw I do have dynamat everywhere in the doors and rear panels. Its all good, awsome sound.
Chief Mario is offline   Reply With Quote
Old 07-02-2009, 07:55 AM   #6
MTron
Drives: 99 Grand Prix
check the plastic clip that covers the wires behind the mirror, seems like it could rattle
check out this thread for some good pics http://www.camaro5.com/forums/showth...ar+view+mirror
MTron is offline   Reply With Quote
Old 07-02-2009, 07:59 AM   #7
JDBeck23
Drives: 2010 Camaro, 2SS/RS
I agree... you can test by turning your sub up and then touching different parts of the mirror to try and push each part down to see where the rattle is coming from.
2010 2SS/RS CGM
American Racing Headers, Magnaflow axle back, Roto-Fab CAI, Audio Integrations Sub box, Alpine Type R 10, Alpine MRP-500 amp, Pro Clips iPhone Mount
JDBeck23 is offline   Reply With Quote
Old 07-02-2009, 09:29 AM   #8
Red Hot SS
Red Hot SS's Avatar
Drives: 2010 Victory Red 2SS/RS M6
Buddy if your system knocks then this is gonna happen.
I had 2 Memphis M3s (400RMS) and those suckers will knock. You get used to it.
I can even identify most car makes and models with a shaky mirror. lol
Virginians Join Group: Virginia is for (Camaro) Lovers!
VIN: 2G1FT1EW8A9118043
Finally Home! (6/16)
Red Hot SS is offline   Reply With Quote
Old 07-22-2009, 03:18 PM   #9
Camar0wn3d
Camar0wn3d's Avatar
Figured out the problem...updated in the original post. This only should apply to 1SS mirrors.
Old 05-15-2011, 05:50 PM   #10
JSC81
JSC81's Avatar
Drives: 2010 1SS/RS M6
Mine actually rattled the mirror bolt lose I had to tighten it. Anyone have a way to keep the mirror from rattleing so bad that it ends up facing the floor instead of behind me where I need it? XD
JSC81 is offline   Reply With Quote
V6 Camaro Performance Upgrades rtcat600man Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 370 02-19-2017 02:24 AM
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 89 02-20-2015 08:43 PM
Rear View Camera VenomZ302 5th Gen Camaro SS LS LT General Discussions 65 05-29-2011 01:55 PM
New Member concerned about rear seat view speedtrip 5th Gen Camaro SS LS LT General Discussions 4 03-20-2009 10:39 AM
Which view do you like the best? GOLDDOG 5th Gen Camaro SS LS LT General Discussions 39 03-11-2009 08:09 AM
