JDP Motorsports
Old 06-21-2013, 11:01 AM   #1
LSXCAM
Drives: 2012 2ss
Baby Cam
Hey guys,,getting ready to do the LS3 conversion on my L99,,i have a set of take off ls3 heads i want to use since they have the lighter intake valves, and i wanted to just use the stock yellow springs. Any idea on what would be a good small cam to use as i dont want to use an aftermarket converter either.
LSXCAM is offline   Reply With Quote
Old 06-21-2013, 11:15 AM   #2
Juice2SS
Drives: 2011 2SS
Hit up Pat G for a custom cam. I'd upgrade the springs anyway though. Just cheap insurance.
Juice2SS is offline   Reply With Quote
Old 06-21-2013, 12:04 PM   #3
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Bad70supreme has a nice voodoo cam. It's on this page. But you should at least upgrade your converter. It will make the ride very fun!
Old 06-21-2013, 12:14 PM   #4
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
Agreed. Even with the stock cam.
Bo White is online now   Reply With Quote
Old 06-21-2013, 12:27 PM   #5
SPCBA
Drives: pleather and Chiclets
you drag race guys and wanting bigger stalls!
SPCBA is offline   Reply With Quote
Old 06-21-2013, 01:24 PM   #6
JEFF75645
Drives: his wife crazy buying mods
What are the stock springs good to?
Gone But Not Forgotten
JEFF75645 is offline   Reply With Quote
Old 06-21-2013, 01:39 PM   #7
Steve@SNL/Monster Clutch
Drives: 2014 SS
You can get a set of pac 1218 or comp 918 springs for cheap and run more lift to better take advantage of the better flowing heads to produce more gain while still sticking with the stock stall. We have done plenty of sleeper cams that work with the stock converter in autos, if you're insistent on running stock springs you might as well run an LS9 cam. Feel free to give me a call to discuss in detail. Chris, 817-750-2000
Steve@SNL/Monster Clutch is offline   Reply With Quote
Old 06-21-2013, 01:45 PM   #8
Drives: 2014 SS
~.570" but worry about valve float with big valve depending on the rpms if you were to use something like an XE lobe.
