JUICEDMOTORSPORTS
Old 06-21-2013, 05:09 PM   #1
47AJV8
Drives: A White Car
HP Gains From Getting Rid of Cats on N/A Motor?
Been awhile since I posted on here last, but title pretty much says it all. I live somewhere where there are effectively no emissions laws and was wondering what HP gains can reasonably be expected with removing my cats on a car that already has intake and exhaust. (ECU tuning is out of the question for now) Thanks!
"From ABS shudder that came on surprisingly early in the lousy brake pedal's travel to a looser rear end than Kim Kardashian"
47AJV8 is offline   Reply With Quote
Old 06-21-2013, 05:23 PM   #2
62nalide
62nalide's Avatar
Drives: 2013 SS
If you won't be tuning the car do not remove them.
62nalide is offline   Reply With Quote
Old 06-21-2013, 05:33 PM   #3
fourmz
Fourmz
fourmz's Avatar
Drives: 2010 2SS/RS 1968 Firebird 1994 Z28
if you pull them I dont think you will see any gains, also, if you pull them and dont tune the ecu to delete the rear o2 sensors your check engine light will light up.
Black-in-Black/Blue out 2010 2SS/RS LS-3 -Magnacharger TVS2300,OD cog belt drive, 3.4" pulley, Janetty smooth idle blower cam,ID-850 injectors,ZL1 fuel pump,MSD boost a pump, ADM FPCM Janetty custom tune,Doug Thorley long tube headers, Corsa catback,C.A.I. Intake, Roto-Fab Big Gulp Scoop, Monster LT1/SC Clutch assembly,Eibach pro kit plus, BMR cradle/diff bushings, Barton Shifter,JRE 3.91 Eaton Tru-Trac rear diff,Barton Short Throw SHifter, Boss 339 20" wheels,Painted heritage grille, Sparks Restoration Inverted blue/black SS emblems, Seibon BB carbon fiber hood, ZL1 front bumper conversion.
fourmz is offline   Reply With Quote
Old 06-21-2013, 05:34 PM   #4
Birm
Birm's Avatar
Drives: Florida Speed & Power
Swap them for Hi-Flows 10-20whp'ish... and if you decide to go with nocats at all, yea youll gain a little, it will be bit more raspy and you will probably smell fuel out the backside...You will need a tune to get rid of the CEL though.
Birm is offline   Reply With Quote
Old 06-21-2013, 06:11 PM   #5
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
as brim said. there is a gain from stock cats to no cats or hfc. and a good gain at that
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 06-21-2013, 07:54 PM   #6
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
If tuning is out of the question then you will need the Solo high flow cats. Those do give a good gain and don't throw a CEL or require a tune. I think I read that there is a way to use the JBA high flow cats to where you don't have to tune and wont get a CEL but someone else will have to chime in on that one as I don't know for sure.
Old 06-21-2013, 11:08 PM   #7
47AJV8
Drives: A White Car
So would about 20 hp be expected as a reasonable gain? With a few little things to deal with of course, thanks for the tips guys.
Old 06-22-2013, 08:26 AM   #8
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
20 is way high. At most you'll get 10 hp. The factory cats are restrictive but not that restrictive. As already stated, unless you get a tune, don't bother doing it.
Old 06-22-2013, 10:30 AM   #9
47AJV8
Drives: A White Car
Oh alright, probably won't bother unless I go for tune, thanks.
Old 06-22-2013, 02:31 PM   #10
Birm
Birm's Avatar
I respectfully disagree. 20 is attainable, 10-15 is avg.
Old 06-22-2013, 04:18 PM   #11
VADER SS L99
I agree as well and if you do the Solo high flow cats you wont need a tune. No cats would be out of the question with out a tune.
Old 06-22-2013, 04:38 PM   #12
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
1000% 10 is very low. those cats from factory suck for hp.
Old 06-22-2013, 04:49 PM   #13
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Well then lets just agree to disagree but I've seen a car dynoed, get hi-flos and a cat back installed, then redynoed and gain just a little over 10 hp with no tune.
Old 06-22-2013, 04:59 PM   #14
Birm
Birm's Avatar
First, anytime there is a change you should allow for a re-learn period......Second, every dyno is different as is every car and the conditions in which they are dyno'd. And third, I have seen 3 cars personally in my club (TBC) who have put on HFC's who have made over 15whp. 10 is on the lowside. But as you said...agree to disagree.
cats, hp gains, removal
